solar thermal heating
/ solar thermal heating #41
I think i know what was confusing me.
The screen collectors will slow the air allowing it to heat up and then with the fans they will pull the air through the unit.
Units such as the can and soffit units, heat up the can/soffit and in return the air that is traveling around them.
(i have heard some people not able to get temps as hot because the air flow is down.)
So on the unit with the screens, does it need a fan? or does the fan give more air flow which in turn gives a better heat return....or am I still confused...lol
You can use the screen type absorber in collectors with or without a fan. If there is no fan than you need a lot of inlet and outlet area. Basically the only think that drives the air through these collectors is that the air heat up in the collector, becomes less dense because of the heating and just rises out the top outlet vents on the collector. The heated air leaving pull new cool air into the bottom vents. These collectors can work quite well, but you have to follow the rules on collector depth and area of the vents very carefully because anything that adds air resistance will slow the flow and make them inefficient. I don't think you will want to put that much vent area in -- basically it would have to be a slot about 4 inches high across the width of the collector wall -- one down by the floor and one at the top of the collector -- don't think the wife would like that :)
My barn collector is a no fan, thermosyphon screen collector:
$350 Solar Heating Thermosyphon Collector
You can use screen collectors with a fan to force the airflow. In this case, the vents can be much smaller and they don't have to be distributed all the way across the width of the collector. This is probably what you want to do.
Gary
/ solar thermal heating #42
That's me :)
Gary
:welcome: Nice thread going here. I spend a lot of time seeing what you have going on over at Build It Solar. Thanks for the research and advice you inform us on.
/ solar thermal heating #43
Well, I figure someday I'm going to need some help with my tractor, which I know next to nothing about -- I'm building up points :)
Its a Ford/New Holland 2120.
Gary
UNUSED (15) SDLANCH PROTECTION MATS (A64281)
UNUSED (15)...
2010 KMC 3376 Peanut Combine (A61307)
2010 KMC 3376...
2019 INTERNATIONAL LT625 6X4 T/A SLEEPER TRACTOR TRUCK (A59912)
2019 INTERNATIONAL...
2007 DRAGON 130BBL VAC TRAILER (A60736)
2007 DRAGON 130BBL...
UNUSED IRGC80 Battery Powered Golf cart (A55272)
UNUSED IRGC80...
Caterpillar 235C Excavator Service and Operation Manuals (A63117)
Caterpillar 235C...
