Softening/conditioning an old flat PTO belt
   / Softening/conditioning an old flat PTO belt #1
KentT
Elite Member
Sevierville, TN
1993 Power Trac 1430 w/Kubota diesel engine
Does anyone have any suggestions on how to soften/condition an old flat-style PTO belt? I want to use one I picked up as a "deflector" on the back of my PT's rough-cut mower (see pic below). Because of the way it is made, I can't simply put chains on it like you normally would. So, I've been thinking of using a piece of a tire or something -- then I happened to see this old belt. I thought I might be able to bolt it to the back edge of the deck. Even if a blade should happen to strike it, it wouldn't be like chopping off chain links and sending them flying...
It's still pretty pliable, length-wise, but is getting stiff and somewhat brittle I'm afraid, when you try to bend it side-to-side. It must be at least 40-50 years old, and I'm not as limber as I used to be either. :p
Does anyone know what they used to use for "belt-dressing" on these old flat belts? Notice that I don't have to worry about it slipping, so it could even be oily, but I don't want something that would swell it/soften it too much...
Thanks!
   / Softening/conditioning an old flat PTO belt #2
Is it rubber or leather?
edited to add: Rereading your post I guess it's rubber. Stop by the local auto parts store and pick up a bottle of transmission stop leak additive. These additives are seal sweller, they soften and condition rubber seals and would probably work pretty good on a old rubber belt.
Not leather. It's got some rubber in it as far as I can tell -- but it certainly has more woven cording than rubber. It's almost as if it is made of cloth... but there's something in the threads, for sure.
   / Softening/conditioning an old flat PTO belt #4
The stop leak would probably work to soften it up. Let it soak in the fluid for at least 24 hours. It takes the fluid a while to do it's magic. :) It will not do anything for the "cords" but it should soften up the rubber nicely.
   / Softening/conditioning an old flat PTO belt #5
As an alternative, stop at a truck stop and pick up a 4$ truck mudflap.. nice thick and heavy.. I made a brush deflector for my rotary mower with that and some hobby angle iron..
cheap and easy...
Soundguy
Soundguy said:
As an alternative, stop at a truck stop and pick up a 4$ truck mudflap.. nice thick and heavy.. Soundguy
I've checked a couple of truck stops here and they want $50 or more for a pair... and didn't have single ones. :eek:
   / Softening/conditioning an old flat PTO belt #7
Check JC Whitney for single mud flap. Just bought one and think I paid $14 for it.
dwhobbs
   / Softening/conditioning an old flat PTO belt #8
What's your address? I got mud flaps coming out of my ears. :) Seriously, if you need one I would be happy to send you one free if you pay for shipping. I could even cut it down to whatever size you need if you like to lower shipping weight. Drop me a PM if interested.
Mike
   / Softening/conditioning an old flat PTO belt #9
Was that for one with chrome and nekkid' wimmin on it?
Seriously.. all the local truck stops and big truck parts stores have em for 4-6$.. just plain black thick rubber ones...
Mine cost me about 15$ to make including the perfed iron and 1/4" bolt hardware I bought from the bulk bin.
here are some pics..
Soundguy
As I recall, they were just heavy black rubber ones -- no chrome ladies or anything... :D
I'm going to do some more checking. Plus there's a local farm store that may have the rubber for horse stalls... I only need a chunk 48" x 6" or so.
The reason I was attracted to the old PTO belt was all the heavy cords in it....
2021 Chevrolet 4500 20FT Box Truck (A51692)
2021 Chevrolet...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A51691)
2006 iDrive...
Unused 2025 Wolverine SBM-12-72W Sickle Bar Mower Skid Steer Attachment (A51691)
Unused 2025...
2024 Wanco WCTS-SM4A-730 800W Solar Integrator Trailer (A51691)
2024 Wanco...
Vermeer T-658 Tracked Trencher (A52384)
Vermeer T-658...
MODERN AG PREDATOR 15 15' BATWING MOWER (A51406)
MODERN AG PREDATOR...
