Softening/conditioning an old flat PTO belt
   / Softening/conditioning an old flat PTO belt #1
KentT
Elite Member
Sevierville, TN
1993 Power Trac 1430 w/Kubota diesel engine
Does anyone have any suggestions on how to soften/condition an old flat-style PTO belt? I want to use one I picked up as a "deflector" on the back of my PT's rough-cut mower (see pic below). Because of the way it is made, I can't simply put chains on it like you normally would. So, I've been thinking of using a piece of a tire or something -- then I happened to see this old belt. I thought I might be able to bolt it to the back edge of the deck. Even if a blade should happen to strike it, it wouldn't be like chopping off chain links and sending them flying...
It's still pretty pliable, length-wise, but is getting stiff and somewhat brittle I'm afraid, when you try to bend it side-to-side. It must be at least 40-50 years old, and I'm not as limber as I used to be either. :p
Does anyone know what they used to use for "belt-dressing" on these old flat belts? Notice that I don't have to worry about it slipping, so it could even be oily, but I don't want something that would swell it/soften it too much...
Thanks!
   / Softening/conditioning an old flat PTO belt #2
Is it rubber or leather?
edited to add: Rereading your post I guess it's rubber. Stop by the local auto parts store and pick up a bottle of transmission stop leak additive. These additives are seal sweller, they soften and condition rubber seals and would probably work pretty good on a old rubber belt.
Not leather. It's got some rubber in it as far as I can tell -- but it certainly has more woven cording than rubber. It's almost as if it is made of cloth... but there's something in the threads, for sure.
   / Softening/conditioning an old flat PTO belt #4
The stop leak would probably work to soften it up. Let it soak in the fluid for at least 24 hours. It takes the fluid a while to do it's magic. :) It will not do anything for the "cords" but it should soften up the rubber nicely.
   / Softening/conditioning an old flat PTO belt #5
As an alternative, stop at a truck stop and pick up a 4$ truck mudflap.. nice thick and heavy.. I made a brush deflector for my rotary mower with that and some hobby angle iron..
cheap and easy...
Soundguy
Soundguy said:
As an alternative, stop at a truck stop and pick up a 4$ truck mudflap.. nice thick and heavy.. Soundguy
I've checked a couple of truck stops here and they want $50 or more for a pair... and didn't have single ones. :eek:
   / Softening/conditioning an old flat PTO belt #7
Check JC Whitney for single mud flap. Just bought one and think I paid $14 for it.
dwhobbs
   / Softening/conditioning an old flat PTO belt #8
What's your address? I got mud flaps coming out of my ears. :) Seriously, if you need one I would be happy to send you one free if you pay for shipping. I could even cut it down to whatever size you need if you like to lower shipping weight. Drop me a PM if interested.
Mike
   / Softening/conditioning an old flat PTO belt #9
Was that for one with chrome and nekkid' wimmin on it?
Seriously.. all the local truck stops and big truck parts stores have em for 4-6$.. just plain black thick rubber ones...
Mine cost me about 15$ to make including the perfed iron and 1/4" bolt hardware I bought from the bulk bin.
here are some pics..
Soundguy
As I recall, they were just heavy black rubber ones -- no chrome ladies or anything... :D
I'm going to do some more checking. Plus there's a local farm store that may have the rubber for horse stalls... I only need a chunk 48" x 6" or so.
The reason I was attracted to the old PTO belt was all the heavy cords in it....
2012 Caterpillar AT1055E Track Asphalt Paver (A51691)
2012 Caterpillar...
2025 SDLANCH SDLD25 UNUSED Crawler Dumper (A53117)
2025 SDLANCH...
2007 50FT 3 CAR HAULER TRAILER (A53426)
2007 50FT 3 CAR...
2014 FORD Transit Connect CARGO VAN (A50323)
2014 FORD Transit...
2020 Can-Am Ryker Rally 900 Ace 3-Wheeled Motorcycle (A51694)
2020 Can-Am Ryker...
Tiger Mowers 80in Super Duty Twin Flail Mower Tractor Attachment (A51691)
Tiger Mowers 80in...
