Socket Set question
/ Socket Set question #21
Do you have any experience with the cordless impacts they have out now? The last time I was out at the local dirt track it seemed like everybody had one. I asked around and they all raved about how good the new ones worked. I figure they must tighten nuts at least fair, I didn't see any tires fly off that night.
/ Socket Set question #22
I agree with Bird about deep well impact sockets. I have 1/2" drive air impact wrench that I will have to get an adaptor to 3/4" for some larger sockets I need for the brush mower, but otherwise, the impact deep wells I bought from Harbor Freight very inexpensively have really served me well. I have lots of other sockets and wrenches, but I find I use the impacts the most and standard well have not been needed. Since you already have the 3/4", and if you have the air power, I would simply add 1/2" air impact wrench, with 3/4" adaptor and some deep well sockets to what you have. John
/ Socket Set question #23
Brad,
Another place to look for tools is at Costco. They carry decent quality tools, and everything (except computers) that Costco sells has a lifetime Costco warranty, regardless of what the manufacturer's warranty is.
If they no longer carry a product that you need to return, they will give you the full purchase price back in cash (or put it back on your Visa). I check Costco first now every time I need a new tool or accessories. And their prices are extremely competitive - many times better than the competition.
/ Socket Set question #24
I have SK and Craftsman ratchet tools, and recently stumbled on to a set sold at our local True Value store. It has a really nice selection of sockets and ratchets in 1/4", 3/8" and 1/2". It was only $99. Just what I wanted to carry in the truck. No major investment, and lifetime warranty.
On equipment, I use mostly 3/8" and 1/2" drive. Like some of the others said, my 1/2" impact has come in very handy..........chim
/ Socket Set question #25
Not sure how old you are, but speaking from that age at which reading glasses are increasingly a part of my life I really like those sockets with the laser etching in BIG numbers on the side! /forums/images/graemlins/crazy.gif
Pete
/ Socket Set question #26
</font><font color="blue" class="small">( it seems to me that even a little compressor like mine can supply plenty of air for a short burst )</font>
That's right, but while I don't have the numbers to back it up, I'll bet you don't get the full volume needed by that 3/4" impact for its full rated power through a 3/8" hose. When I was repairing air tools, I worked on quite a number of 3/4" impacts, including the IR261, and I could check to make sure they were working properly with a 1/4" hose, but you certainly were not going to get full power. Since my own air tools were 1/2" and smaller, I normally used 3/8" hoses, but every 3/4" impact I got in for repair came with couplers for a bigger hose (1/2" at least). I made up my own adapters so I could use the quick couplers on my 1/4" and 3/8" hoses in my shop.
So you're also right in that you have a huge mismatch between compressor, hose, and wrench, but if it has enough power to do what you want to do, so what, who cares? That's all we want from our tools anyway, isn't it; to do the job at hand. /forums/images/graemlins/wink.gif
In most cases, a very short burst of air serves the purpose of breaking a nut or bolt loose, or even of tightening it back. But the "rated" power is usually either a 5 second air flow of its rated SCFM (sometimes referred to as working rating) or its "ultimate" power rating, which is continuing the rated air flow until it just stalls and can't turn a bolt any farther. And like horsepower ratings for tractors, it doesn't really matter what the number is if it's doing the job. /forums/images/graemlins/wink.gif
/ Socket Set question #27
</font><font color="blue" class="small">( Do you have any experience with the cordless impacts they have out now? )</font>
None, at all, Brad. I can certainly see how they could be handy at the race track, or for someone doing work in the field when he doesn't have a compressor or generator, but I don't know anything about them beyond the fact that such exists.
/ Socket Set question #28
Cheer up Pete. Soon will come the day when you are placing wrenches by feel as the Bifocals are on the bottom instead of the top and of course they are not set for the distance you are working at.
Egon /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
/ Socket Set question #29
$35 for both at the flea market, does the job, wrenches could have a better fit, eh couldn't pass it up.... /forums/images/graemlins/blush.gif /forums/images/graemlins/grin.gif
/ Socket Set question #30
Lots of good replies here. When I buy tools I go for the Craftsman tools like a lot of others here. One caution though, there are a lot of posts about impact wrenches. Impact wrenches need impact sockets. Impact sockets are hardened and usually (but not always) have a dull black finish.
Then why not buy all impact sockets you ask? As mentioned by several posters, impact sockets usually have thicker walls than standard sockets. There WILL be times that an impact socket won't fit over the nut/bolt you are trying to get at.
Another point is that, generally, standard sockets are 12 point sockets and impact are 6 point sockets (there are always exceptions to this, but they are not common). The 12 point sockets are easier to drop onto a bolt/nut without rotating the handle/socket much. The 6 point, of course is stronger for the impact.
You will always use a 1/2 inch drive. A 3/4 inch drive is just not a handy tool to use. for instance, it won't fit in your back pocket and you'll be afraid to lay it on the fender because its too big to just lay there or too heavy. I'll start a job with a 3/8" drive. If a 6" handle on a 3/8" ratchet won't work, I'll switch to the 1/2" drive. I have a 3/4" drive for the truly huge jobs and buy sockets one at a time as I need for this.
There will come a time when a cheater is required to persuade a nut to come off (because the impact drive you have won't fit in the space available). For this reason, I have round handle 1/2" and 3/4" breaker bars. That way a nice length of 3/4" or 1" pipe will fit over the handle as the cheater. [Breaker bars are socket wrenches without the ratchet, they usually have just a swivel joint at the head.]
Any new job is always the excuse for a new tool. Make sure to take advantage of that when undertaking household projects. Isn't that the rule you used to get your tractor? Well, it works for drills, saws and wrenches too!
Happy shopping,
Dave
/ Socket Set question #31
</font><font color="blue" class="small">( : 1. Do I need metric, standard, or both?? 2. Should I go with a 3/4" set, or a 1/2" set?? And 3. Standard or Deep well or both? And if you know of a place online that sells them pretty cheap (but still good quality of course) that would help as well. Thanks!
-Brad )</font>
1. I have found that is good to have both metric and sae. Some implements are sae while most of my tractor nuts/bolts are metric
2. A 1/2 inch set seems to be best all around size for me but I also use a 3/8 set often. I also reccomend the air tools as others have suggested
3. I use deep well impact sockets more than shallow well sockets I have also bought most of my air tools from Harbor Freight . I bought most of my hand tools from sears IMO you cant beat craftsman for quality.
I also keep a cheap set of metric and sae wrenches in my tractor tool box along with a set of pliers and a hammer for use in the field.
/ Socket Set question #32
I picked up a 1"plus sized socket set from harbor freight.. had a breaker bar and ratched.. 1/2 drive stuff.. went up to 2 1/4
Great set.. I've kapedn axle bolts off the ford tractor with it ( 450 ft# ).. and twisted heads off 1/2 bolts on an old rusty disk with -NO- problems... The sockets or ratchet or breaker bar show no signs of use after 3 major tractor projects with them now..
Soundguy
/ Socket Set question #33
absolutely enough air!!!!!!! need bigger hose...... /forums/images/graemlins/wink.gif
NOW HEAR THIS GUYS!!!!!!!ONE OF MY NEIGHBORS CAME over to see me the other day...and in the back seat he had this huge box2'x 2.5'...wide open that he jist got at wal-mart...
i have a high quality 3/8" air ratchet and have been thinking bout gittin a 1/2!!!!!!
this set had a 1/2" impact...3/8" air ratchet...air hammer/chisel...high speed angle grinder...and 2 other tools????!!!!!!!!!!!!!!!!!$62.00!!!!!!!!!!!!!!!! whole set
now i know theses r china dools but!!!!!!!!! i donot use them all of the time and this kit is it 4 me!!!!!!!...oh yeah!!!!1/2....impact shallow and deep well...sae and metric will do jist bout anything u will eva need ..think i'm gonna go git that kit today!!!!! i e i do will put on a pic... i jist thought it was a killer deal...kit had all sortsa blow guns and other attach.s too!!!! /forums/images/graemlins/cool.gif /forums/images/graemlins/cool.gif /forums/images/graemlins/cool.gif /forums/images/graemlins/cool.gif /forums/images/graemlins/cool.gif
oh yeah!!!!!one other thought!!!!...whenever u take one of those big nuts/or bolts off!!!!!! hit it with some never sieze b4 puttin back inand you'll have a much easier time gittin it off nxt time...especially on blades and tire lugs... /forums/images/graemlins/cool.gif /forums/images/graemlins/cool.gif
i always make sure i put some on the tire lugs on all of the vehicles..makes 4 a very quick tire change with the least amount of effort!!! /forums/images/graemlins/grin.gif /forums/images/graemlins/cool.gif /forums/images/graemlins/wink.gif
/ Socket Set question #34
Here is a list of what brands to buy that in my opinion are the best avaiable. All come with a lifetime warranty.
Snap-On
Mac Tools
S&K
Craftsman
All are quality sockets with Craftsman being the easiest to break. I have replaced more Craftsman sockets that I own over the rest. As for the cheaper Chinese sockets. You will get what you paid for. If you are going to use impact tools I reccommend you buy impact sockets. Standard sockets do not hold up as well as the impact sockets. A picky tool sales guy may not replace a broken standard socket if it shows signs that it was used on an impact wrench.
/ Socket Set question #35
Jim:
You may not know this but, the Kobalt line of tools that Lowes sells is made by Snap-On. Same guarantee and a lower price. I have some of their open end wrenches and they fit in you hand really well, just like Snap-On.
I like Williams tools. They aren't as readily available as other brands. Mostly they are sold by machinery houses. They make a wicked 3/4" and 1" drive sets. I have the 3/4" and it's very stout.
/ Socket Set question #36
Thanks for the info on Cobalt tools at Lowes. I never heard of them. There is a store near me and I will have to check them out. Snap-On tools are the best in the industry.
/ Socket Set question #37
If all you're going to work on is farm implements all you need is a cutting torch and a Crescent wrench. /forums/images/graemlins/smile.gif Craftsman has been around for ever, good quality but half the time they don't have the tool you need in stock when you try to warranty one. When I was bustin' wrenches proffessionally it was a PITA to remember to bring the socket from work to a Sears store just to find out they didn't have what I needed. Stanley tools seem to have good fit and finish and Stanley owns Mac tools so they just might be made in the same factory. The Kobalts look good and if they're made by Snap- On they ought to hold up. The racks at Lowe's seem to be well stocked so you would stand a better chance of finding the socket you need when you take one in for warranty.
/ Socket Set question #38
</font><font color="blue" class="small">( Jim:
You may not know this but, the Kobalt line of tools that Lowes sells is made by Snap-On.)</font>
Kobalt tools are made by Danaher, the same company that makes Craftsman.
Ken /forums/images/graemlins/smile.gif
/ Socket Set question #39
I got a 1/4", 3/8" and a 3/4" set. I don't have a 1/2" set because it would be almost entirely overlapping with the 3/8" and the 3/4". I find that the 3/4" set (along with a matching set of large wrenches) is the only thing to do some jobs while I never miss the 1/2" set.
/ Socket Set question #40
</font><font color="blue" class="small">( Kobalt tools are made by Danaher, the same company that makes Craftsman )</font>
Danaher is also the parent company of Matco Tools.
DRAGON 500 BBL FRAC TANK (A67714)
DRAGON 500 BBL...
PALLET OF ALUMINUM PIPING (A68842)
PALLET OF ALUMINUM...
x (A68191)
x (A68191)
2013 ALLMAND MAXI-HEAT MH1000 HEATER (A68842)
2013 ALLMAND...
XTREME XR1147 TELESCOPIC FORKLIFT (A65056)
XTREME XR1147...
2023 CRUISER RV SHADOW CRUISER (A67714)
2023 CRUISER RV...
