soap stone woodstoves?
/ soap stone woodstoves? #21
I have an extra large dutch west with a catalytic converter. It is 4 years old and I have never cleaned or replaced the converter. The stove did take a while to get used to but now I would never change it. I can keep a fire going 12 hours and the coals last longer.
PTRich
Pete,
went to look at the Hearthstone stoves tonight. They look real nice. The one we looked at was the homestead. Good price, good looks, small enugh so as not to take up a lot of room, but big enugh to put off some heat. We are still looking, but we are leaning toward this one. Any problem with yours? Would you buy anouther? Thanks.
/ soap stone woodstoves? #24
We got the Phoenix model as it was the largest that would fit into our fireplace. My dislikes are (1) it doesn't draw as well as others, but once I gave up and used a bit of firestarter it did just fine, and (2) the ashpan has no back so it's very easy to dump hot ash and coals on your floor./w3tcompact/icons/shocked.gif I get around this by using a shovel and ash bucket instead of the dustpan looking stock unit.
Do I like the stove? Absolutely! I love the heat sink of all that stone. And I love the way you can remove a few fire bricks to access the exhaust stack; it sure makes chimney care a breeze! Run a brush down the pipe from the roofline. Open the stove, remove two bricks, stick a shopvac nozzle inside and suck up all the black stuff. Easy!
And yes, the next stove will be a Hearthstone unless someone comes up with a way better product before then!
Pete
Cool. Thanks. The price is right, so I think I may go that route.
The one I was looking at was about $1600.00.
Ya, the soap stone ones are a little more pricy. But they look nice. And the wife likes them
This is the one I think we will be going with. Seems to fit all our needs.
here is the page with all the specs.
<A target="_blank" HREF=http://www.hearthstonestoves.com/Stoves/Wood/index.cfm?Prod=Homestead>http://www.hearthstonestoves.com/Stoves/Wood/index.cfm?Prod=Homestead</A>
what ya all think?
/ soap stone woodstoves? #31
Nice looking stove! As with all Hearthstones, make sure the dealer shows you how to access the pipe from the inside (there's a trick to moving the firebricks without punching holes in the insulation) so you can clean your chimney without disconnecting things in the back. My wife and I did it the wrong way the first time, and she looked like a coal miner when we were done! /w3tcompact/icons/shocked.gif
Pete
<font color=red>My wife and I did it the wrong way the first time, and she looked like a coal miner when we were done! </font color=red>
AH, I don't think I will let my wife read this post./w3tcompact/icons/smile.gif
/ soap stone woodstoves? #33
I've got one. We bought it two seasons ago. see www.woodstove.com for details. I really like it. the heat it throws is much more even that a metal stove and the stove will throw heat much longer than a metal stove. I also think they look great. The down sides are: they take longer to heat up when you start the fire, they run better with smaller peices of wood. As far as I am concrened it's not much of a down side.
Good luck with your stove hunt. Dan
TOOTHED BUCKET ATTACHMENT FOR MINI EXCAVATOR (A58214)
TOOTHED BUCKET...
WIGGINS 5K FORKLIFT (A58214)
WIGGINS 5K...
New/Unused 72in No Till Seed Drill (A61166)
New/Unused 72in No...
INSPECTION (A61165)
INSPECTION (A61165)
2009 CAROLINA  16FT EQUIPMENT TRAILER (A58018)
2009 CAROLINA...
2018 FORD F450 XL 4x4 CREWCAB 5K LB SERVICE CRANE (A62613)
2018 FORD F450 XL...
