So you want to do your own pipe fence??????
   / So you want to do your own pipe fence?????? #11
Harv, thanks. When we bought our property, we immediately put up the ubiquitous rural Florida fence, which consists of 4' high, 4" x 4" field fence (called "hog wire" around here) on 3" wood posts, using 3, 6" posts at each corner with box bracing. It's cheap, goes up fast, and lasts a reasonable amount of time. We put it up before we did anything else, because the local kids had been using the place to trail ride their ATVs, and we weren't going to be there to stop them in a friendly way. We also knew that once we moved there, we'd need to contain our dogs, a couple of adopted greyhounds that couldn't find their way home if they got out of sight.
But, that kind of fence has a "poor boy" look to it, and I can't help thinking about something a little nicer. I also like the idea of doing a job only once because it was done good.
The hog wire fence is stretched tight from the corners to the middle braces and almost stands up by itself without any intermediate posts. We replaced some barb wire fence on existing posts with the hog wire, and found that after we had pulled it tight with the tractor, that as we went down the fence stapling to the posts, the fence would stand up by itself for the next two posts because it was so tight. We stretched about 400' at a time. The intermediate posts are only used to help it stand up, and there are no horizontal posts, except for the corner and middle box bracing.
Some folks add horizontal boards, usually 1"x6", to make it look like a 2, 3, or 4 board fence. But, that requires a lot more maintenance. I've also learned that the tax assessor considers a pasture fence to have no value for assessment purposes, but adds to your assessment for a board fence. He'd probably consider a pipe fence to be a pasture fence because he's trained to look for boards, not welds...
So, I like the idea of your welded fence, and have been giving it some thought for the future. I also like to have something just a little different than everyone else, especially if there are logical reasons behind it -- makes me look like I'm smarter than I am. /forums/images/graemlins/grin.gif
Let me add that I don't like conventional chain link much - usually looks pretty bad after a while, and, in our area, says either industrial or trailer park.
   / So you want to do your own pipe fence?????? #12
Hey Harv:
One thing how do you make that little bent part that is set between the two pipe sections? is that just a flat cut that is then bent like a twist slightly so it fits on the pipe halves?
Mark M /forums/images/graemlins/ooo.gif
</font><font color="blue" class="small">( One thing how do you make that little bent part that is set between the two pipe sections? is that just a flat cut that is then bent like a twist slightly so it fits on the pipe halves?)</font>
Ahhhhh, the piece that makes it all work. /forums/images/graemlins/smile.gif
A friend of mine punches those out in his little factory. They cut the pipe and then put it in punch press for an adjustment.
They're less than a buck apiece. And when you think of the labor to cut in between posts, not a bad deal.
Don,
If you do a search from last year I had two threads going. One was "fun at work" and the other was "fun with gates".
In one of those I've got some examples of what you can do to spice up a pipe fence. In one I double railed it at the top with about a seven inch or so gap between them. In the gap I put brands, like cattle brands, that I'd come up with from the family names.
Another thing I've done with the double toprail is put in triangles. It makes it look slick. The sky's the limit with any imagination at all. I can get started thinking about doing pipe fence and get all excited. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
   / So you want to do your own pipe fence?????? #15
Harv
This year I intend to replace my 30year old stock field fence. I’ll be doing almost 40 acres so I think that I will build my corner posts and associated bracing in the shop with sch 40 pipes. Then drag them out and place them were I need to. I’ll do the same with center bracing then stretch new red brand field fencing between them. My cows are pretty content to stay around but since the neighbor to the north doesn’t do anything with his field come August the neighbors untouched field is a pretty strong temptation.
Attached is a picture of the lower 20 last week after our very rare ice storm.
I have really enjoyed your gate and fencing pictures. Thanks for sharing with us.
Eric
   / So you want to do your own pipe fence?????? #16
Harv,
Would these pieces be available to the general public?
PJ
Morning PJ,
They're being made at and will be available from http://www.planopower.com/store/whipper-clipper.shtml
They don't have them online yet but will soon.
I'm helping them design accessories for the ring along with a step by step set of instructions for those who value their dollar more than their time.
Morning Eric,
It sure is pretty but it looks a mite cold. /forums/images/graemlins/smirk.gif
The only problem I'd have with your idea would be premade H fixtures and corners work and look good on level ground. I got the sneaking suspicion some of your land isn't.
BTW the HD in Weatherford Texas carries corners and H fixtures all welded up with two and a half inch (2 7/8") schedule eighty pipe. It's a shame too, all that good steel and the horizontal pieces are too short. /forums/images/graemlins/crazy.gif Some folks forget the strength in an H fixture comes not only with it's design but a lot of it comes from distance between the posts.
If I was you I'd premake those for the flats in the shop and build the ones in place that are where the terrain is horizontally challenged. I use 96" as the key number. Posts eight feet long and the horizontal spacing between the posts, eight feet too, nice round even number.
You only regret digging a hole too deep for a couple of minutes. But you can regret not digging it deep enough for years and years. /forums/images/graemlins/grin.gif
   / So you want to do your own pipe fence?????? #19
That's a pretty neat picture, 40Kchicks!
More like a painting than a picture...you are a luck guy living in a nice place like that... /forums/images/graemlins/smile.gif
   / So you want to do your own pipe fence?????? #20
Thanks Harv,
I think this type of fence will work well in my part of the country (dry).
PJ
2007 Peterbilt 335 Mickey AO-A Battery Truck (A50323)
2007 Peterbilt 335...
2016 J&M 1122-20T X-Tended Grain Cart (A50657)
2016 J&M 1122-20T...
2024 AGT INDUSTRIAL QHT-500FL CONCRETE BUGGY (A51243)
2024 AGT...
2016 Laymor SM300 Towable Ride-On Rotating Sweeper (A50322)
2016 Laymor SM300...
Deutz-Allis GVL Poly Corn Head (A50514)
Deutz-Allis GVL...
2018 KENWORTH T370 T/A DUMP TRUCK (A51406)
2018 KENWORTH T370...
