So, look what followed me home from the woods today
   / So, look what followed me home from the woods today #1
square1
Michigan
Ford 1700 4x4 w/ FEL
Can I keep it?
A section of spring tooth harrow (I believe). Somehow going to affix the springs to a bar / pipe that can be quickly attached to the FEL with the points down to "rake" the woods after clearing to get the small trees / brush pulled out. Hopefully will be able to flip the bar over and use the same attachment to push the brush up into a pile to burn.
   / So, look what followed me home from the woods today #2
I wish I could find one of those and get it to follow me home!
What would you use it for?
   / So, look what followed me home from the woods today #4
I would use it to rip the grasses each Spring to help control the KR Bluestem grass that is taking over so many hayfields around here! I think it would be better suited to my land than a disc. I have a lot of rock, and the disc would just roll over the rock and miss the grass portions. I could be wrong, but I think the spring tooth harrow would do me a better job.
Well this piece is only 32 inches wide, you might be out there a while ;)
   / So, look what followed me home from the woods today #6
Yes, but I would be covering rugged areas and also need to get into tight spaces. Not sure I could manage with something 6 feet wide, for that purpose, like I can with a brush hog! But 3 feet would be better!
   / So, look what followed me home from the woods today #9
Why not? I want one! :)
Your wanting one in Texas and me having one in Canada makes it cost prohibitive. Shipping would cost you way more than what they are worth to begin with. There has got to be some spring tooth harrows in Texas, somewhere.
H&R Agri Power in TN has a 5 footer for sale on IRON Search.com
   / So, look what followed me home from the woods today #10
FG19..... Great find.....
It appears to have been a horse implement ???
If so, now you have to build a 3pt adapter to bolt it to so you don't have to cut, drill, weld on it to preserve the antique value...
It appears adjustable for depth of cut... So you should be able to control rock and root entanglement issues and the like...
Post pictures and results of how it works...
Good luck
2012 FORD F-650 ROUSTABOUT TRUCK(INOPERABLE) (A52472)
2012 FORD F-650...
2012 Ford F-450 Altec AT200A 30ft Bucket Truck (A50323)
2012 Ford F-450...
New 20ft 5/16in G70 Tie Down Chain (A50323)
New 20ft 5/16in...
2015 Ford F-250 (A50120)
2015 Ford F-250...
IMPORTANT PLEASE READ!!!! TERMS AND CONDITIONS (A51573)
IMPORTANT PLEASE...
2015 Kenworth T400 T/A Vactor 2100 Plus Combination Sewer Jetter Vacuum Truck (A50323)
2015 Kenworth T400...
