So does anyone use non ethanol gas
   / So does anyone use non ethanol gas #21
I have not changed the fuel filter in 12 years and 253k miles on my minivan so that is not unreasonable, if you maintain your equipment, we rarely changed fuel filters when farming either but we payed close attention to the quality of the fuel used
Interesting, but how do you assess quality of fuel?
I usually buy from the same station and get good results. However, I had one tank in my passenger car that got horrible mileage. I don't know how I would be able to insure gas quality other than by buying from a brand name dealer.
Years ago, the common knowledge was that Sinclair gas was better quality, and 76 has advertised that they are better quality (but that is from the vendor itself).
Short of testing gas, I don't know how one would be able to say one gas was good and another was bad until it was already running (and potentially damaging) a piece of equipment.
   / So does anyone use non ethanol gas #22
Non-ethanol here is about 30-40 cents more per gallon. I use it about exclusively in my lawn tools, and as much as practical in my vehicles. I can get 10-14% better gas mileage in my truck, so the price is a wash, but the real difference is the truck is much more responsive. Try it sometime and see after a couple tanks of non-ethanol how much more responsive your vehicle is and if you mileage improves. I'd like to hear others' feedback on this. Call me crazy, but I believe if everyone purchased non-ethanol on purpose, after a short supply disruption, the tables would turn to where it is cheaper than ethanol added and our food prices would eventually benefit as well. Government is actually talking about pushing to 15% ethanol now. Problems will persist and become more apparent. My opinion for what it's worth.
   / So does anyone use non ethanol gas #23
According to the map link posted earlier (thanks) I can get Ethanol free gas 60 miles from here at a Loves truck stop. But I have a stihl weed whip that takes 89 octane or better. Wondering if it will have enough octane.
   / So does anyone use non ethanol gas #24
Call them and ask them what the octane is?
   / So does anyone use non ethanol gas #25
The place that I buy ethanol free from only has 92 octane premium in ethanol free. It's worth a phone call before driving.
BTW, CA (and a few other states) definitely has a dearth of ethanol free. Check out some of the other states (638 stations in Wi.; only 6 in Calif.).
   / So does anyone use non ethanol gas #26
Since most of my time is in the SF Bay Area... not many options.
   / So does anyone use non ethanol gas #27
You can get ethanol free gas here in sw va. On almost every corner and is typically only .05-.08 cents higher than 10% ethanol. Lots of rural stations are all non ethanol only. I quit running ethanol in my saws and mowers and it has really eased my problems a lot. No more hard starts or rebuilding carbs
   / So does anyone use non ethanol gas #28
I use ethanol free gas in all my dozen or so small engines. The cars are the only things that we put the 10% ethanol in.
   / So does anyone use non ethanol gas #29
Hi MossRoad, you haven't changed your fuel filter in 12 years?!?!? :eek: That seems remarkable! Maybe I misread.
Nope. You read that right. Never changed it. If I did, it was so long ago that I forgot. I'm on my third battery, though. :laughing: I've just never had any problems with the thing. It almost always starts, with the exception of under zero degrees, when I sometimes have to give it a shot of starting fluid.
I'm also on my original spark plugs. I have spares, but never changed them yet. Maybe this summer.
I'm somewhere around 5-600 hours in 12 years. I avearage about 1.5 gallons per hour. Maybe a tad less.
I have 3 six gallon cans of gas that I rotate, putting 4 gallons in the tractor at each fill. In the summer, I go through about a gallon per week mowing. Harvesting firewood 4-5 weekends per year, I go through 5-6 gallons per weekend. Snow plowing is rare. So, 25 gallons for mowing, 25 gallons for firewood, and maybe 15-20 gallons for brush hogging/special projects depending on who asks. That adds up to about 75 gallons per year at most. So, about 800 gallons through the filter in 12 years is my best guess. Doesn't sound like that much when you add it all up. I do use stabilizer in my 3 cans but only in the fall when all brush hogging, firewood, mowing and leaf cleanup is done. Those three cans can sit all winter if there is no snow. That's about the only thing I do special.
Personally, I think people get overly worried about fuel contamination(I'm talking about gasoline, not diesel). If you rotate out your fuel on a regular basis, run your tanks down, run your small 2 stroke engines out completely, and if you have to store gas more than 6 months, use a stabilizer, keep your filler area clean as well as your gas can nozzles, you should be fine.
It's worked for me. :thumbsup:
   / So does anyone use non ethanol gas #30
I only run non-ethanol premium in all my mowers, saws, etc. You can find gas stations that carry it here:
Ethanol-free gas stations in the U.S. and Canada
Just curious why you do that?
Unless an engine manufacturer specifically calls for premium (high octane) gas in an engine, most folks agree that it is a waste of money and can overheat your engines.
Not critisizing, just asking. ;)
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
UNUSED FUTURE 20' WROUGHT IRON BI-PARTING GATE (A57193)
UNUSED FUTURE 20'...
UNUSED FUTURE 29" PALLET FORKS W/ MAST (A57193)
UNUSED FUTURE 29"...
(5) Ladders (A56469)
2014 Ford Transit Connect Cargo Van (A54814)
2014 Ford Transit...
UNUSED CAPTOK CK-P45 MINI HYD BREAKER HAMMER (A57193)
UNUSED CAPTOK...
