Snowplow for Kubota 2910
   / Snowplow for Kubota 2910 #11
I'm going to remove the bucket and make it quick attach to the loader. If this turns out not to work I'll probably cut the blade down to 6'. Good luck. I'll post photo's once mine is finished.
Rick,
You'll need a third valve to power angle the plow...
Are you going to use a diverter or run off rear remotes?
Regards,
Chris
   / Snowplow for Kubota 2910 #13
I'm going to add a Fasse Diverter valve; $330.00 from Deere.
It's going to be cheaper and a cleaner set up to do it that way rather than add a beyond kit and valve to the tractor.
   / Snowplow for Kubota 2910 #14
Thanks for the pics. Looks good so far. I'm interested to see how you attach the plow to the tractor. Are you making a subframe of some sort. Keep the pics coming. Thanks.
Toolguy,
I am making a subframe to go back to the loader frame.
Still working on the geometry for that...
Regards,
Chris
   / Snowplow for Kubota 2910 #16
You're looking good there. Anxious to see more, so good luck with the progress. Maybe we will get some snow to try it out on 'when' you are finished and ready. /forums/images/graemlins/wink.gif
Beenthere,
I just got in a little while ago.... Stopped and bought myself a mig welder.
I used a neighbors to get as far as I have but I wanted one for myself.
I picked up a Lincoln 3200HD... 135 amp DC mig welder.
So I should be able to make some good progress this weekend.
Regards,
Chris
   / Snowplow for Kubota 2910 #18
Hey!, Any updates since the purchase of your new welder?
Update:
I picked up the steel for the frame on the tractor.
I'm using 2x2x1/4 inch angle stock.
I cut all the peices and bolted them in place.
I clamped the frame together and tacked it with the welder.
I removed the frame from the machine and proceeded
to do the final welds.
I picked up the 2X8 inch 2-way hydraulic cylinder
from TSC and had the hoses made up and added the
quick connects for the loader valve.
I have a few more peices to do this weekend and I'll
be close to done.
The final part of the project will be the angle cylinders.
I'll take some picks this weeked.
Regards,
Chris
2021 Allmand Bros Maxi-Lite II 20kW Towable Light Tower (A55973)
2021 Allmand Bros...
2010 GMC Sierra 1500 4x4 Crew Cab Pickup Truck (A55973)
2010 GMC Sierra...
2023 Kubota U27-4 Mini Excavator (A55973)
2023 Kubota U27-4...
500 BBL WHEELED FRAC TANK (A58214)
500 BBL WHEELED...
2022 RAM 2500 HEAVY DUTY (A55745)
2022 RAM 2500...
1999 FREIGHTLINER FL80 SWABBING UNIT TRUCK (A58214)
1999 FREIGHTLINER...
