snowman22
   / snowman22 #1
snowman22
gilmanton nh
case 580c
i have a case 580c loader backhoe that the bucket will not go down. could this be causedby low fluid or the weong hydraulic fluid? it does have a leaking hose in the hoe boom.
   / snowman22 #2
Check the fluid level, fix the hose, then see if it still does not work. You may have bucket pins that are rusted tight or bent. But if the hydraulics are not in good shape none of that matters. What year is yours? BTW the type of hydraulic fluid is probably not a significant factor. That would be more about seal longevity and cold weather performance.
   / snowman22 #4
Another welcome - are you referring to the hoe bucket, or the loader bucket? Sounds like you're talking about the hoe bucket, but more info would help.
If it's the hoe bucket, is it the boom, dipper or bucket itself that won't move?
Generally, down is easy :D It's up that's hard - but if yours still has the boom latch in place, if that is latched the boom would only move if something breaks.
Without more info, it's hard to know if we're talking down to you or if you just bought the TLB and need to know everything there is to know - please clarify if possible... Steve
   / snowman22
my problem is in the bucket of the front end loader, it is a 1977 580c the hydraulics have been working great up to this point, however i let a friend use it for the last year and when i went to bring it back home to use it he informed me of the problems. i am in the process of repairing the hydraulic leak but wanted to get a headsup if this doesn't take care of my issue
   / snowman22 #6
I guess we each have our own definition of the term "friend" - the few I call that would have either fixed it or had it fixed. The other kind don't get to borrow my stuff.
My hoe is a 580B, which has a totally different return to dig system (uses an extra hyd. cyl. in the curl circuit, that's connected to loader arms and pumps extra fluid into the curl circuit) than the c, d, and e models - those later ones used a cheaper to produce, electrical solenoid to directly change the bucket tilt as you raised and lowered the loader - I don't have manuals on those, but here's a link to the C's parts blowup
Official Case Construction Equipment Online Parts Store and Parts Look Up. Parts for Case Equipment and Construction Equipment. Parts Store for Case Wheel Loaders, Case Excavators, Case Skid Steers, Case Original Parts.
Maybe the solenoid (shown in the above as an un-named block, near items # 46-47) got stuck and is messing up your loader valve somehow? As I said, my familiarity with that system consists of knowing it exists :confused:
Does your loader refuse to lower whether you use power down or float? If you put it in float, turn off the tractor and come back tomorrow, will the loader STILL be up?
Gotta admit, this one's a teaser... Steve
   / snowman22
i have a 1977 case backhoe 580c the control for the down on the bucket feels like it is frozen . the up works fine could this be a n o ring in the control valve or something else?
   / snowman22
i have recently found out that problem is actually that the control will not move forward to let the bucket down it feels like it is locked up. it will pull back and raise the bucket. could this be an o ring in the control valve or maybe some dirt?
   / snowman22 #9
Remove the spool and check for debris.
Also look inside the cans on the bottom of the valve for broken springs or rust.
   / snowman22 #10
That could be something as simple as an external blockage on the joystick linkage, or much more complex - that loader valve spool has dual poppet type check valves, an adjustable spring-loaded float with (IIRC) 3 small ball bearings that snap into a detent groove, and multiple o rings - I've worked on everything from hot rods/dragsters to heavy equipment (my own), industrial process automation systems, etc, and after seeing what's inside that valve I wouldn't attempt to take it apart without a manual. Too many "surprises" inside :eek:
I have two, the original Case paper manual ('bout 5" thick) and the 580B version from here
CASE 580CK C Loader SERVICE Manual PTS -2- MANUALS 580C for sale
The paper ones are expensive, bulky, and not as friendly - only reason I have one is because (at the time) that was all you could get. IIRC, it cost around $150.
No complaints about the one I linked to, you can get just the service manual but the parts manual is useful too.
Not knowing what your background/experience is, hopefully I'm not "talking down" to you, not my intent - personally I'd rather be warned about something like this than to find out the hard way what's in Pandora's box :rolleyes:
If you're desperate and can't wait for a manual, I might be able to post a couple of pages from mine - let me know what you want to do... Steve
UNUSED IRANCH 1R EXCAVATOR RIPPER (A54757)
UNUSED IRANCH 1R...
2008 Lexus RX (A55758)
2017 Ford F-450 Crew Cab Mason Dump Truck (A53422)
2017 Ford F-450...
UNUSED LANDHONOR PF-11-3500G PALLET FORKS (A54757)
UNUSED LANDHONOR...
Brent 640 Gravity Wagon (A50775)
Brent 640 Gravity...
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
