SnowMageddon
/ SnowMageddon #43
And for the envelope, please... The bike lube in question is?
Thanks!
FWIW: I use Fluoramics antirust spray, HinderRust. It is a penetrating, light oil.
All the best,
Peter
On the squeeking, I have stopped using conventional lube. I purchased a bottle of this bike lube. Spoke to a friend who bikes a lot and swears by this. It does seem to last longer than regular lube, but my rams make a ton of noise in steering. This works but I wish the rams PT provides had lube points.
/ SnowMageddon #44
I am not home but I think it is WHITE LIGHTNING CLEAN RIDE. Find it on amazon. It is a wax based lubricant. Used on bike chains for guys who do serious off road.
/ SnowMageddon #45
I have used that White Lightning on a lot of things. It has a wax base and alcohol, where the alcohol lets it get into where it needs to be, then just leaves the wax lube. I have used another one called Finish Line, which is a Teflon Based Bike Chain lube. They seem to get into places better then the Teflon Based Gel Super Lube. The Spray Super lube is nice if you find it cheap enough.
/ SnowMageddon
Hmmm sounds like it might be good for changing out wheel motors too. Sort of like waxing with heat.. I'll have to order some and keep it around. Thanks for the tip Jeff / Woodlandfams ..
2012 HEIL (A60736)
2012 HEIL (A60736)
CAT 930M (A58214)
CAT 930M (A58214)
2020 GENIE GTH-5519 TELESCOPIC FORKLIFT (A59823)
2020 GENIE...
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58214)
RIPPER ATTACHMENT...
2012 PETERBILT 386 SLEEPER (A59906)
2012 PETERBILT 386...
26120 (A56859)
26120 (A56859)
