Snowblower (Deere Model 49) Restoration
   / Snowblower (Deere Model 49) Restoration #1
Gravel7
Deere 318
Hello,
I probably didn't get this post into its appropriate sub-forum or whatever. I apologize if this is in the wrong spot:confused:
Anyway, my question:
Just finished sandblasting and priming my snowblower. I am eager to get it all reassembled. I put on 2 coats of RustOLeum metal primer and so far 2 coats of the Valspar JD Yellow implement paint that Tractor Supply carries. My question is how many coats of paint would you guys apply? I was originally thinking I would put on many coats while its all apart and everything is easily accessible. But after 2 coats, it seems like plenty to me. And, I now remember that I #$ing hate painting:mad:
Does this paint go on a little thicker than normal paint or something? Seems thick to me. I also did 2 coats of black high gloss implement enamel on the auger.
So, more coats of paint or she's good:confused2:?
Thanks for any opinions!!
Mike
   / Snowblower (Deere Model 49) Restoration #2
wish i could help but really not sure. i would take my time and check other sources. you've already got the hard part done so don't rush it. i know how it is to want to finish a project and later became sorry i didn't put alittle more effort into it.
steve
   / Snowblower (Deere Model 49) Restoration #3
hi i am caseyandlacey im just started would you tell me if i am here but i cant help you
   / Snowblower (Deere Model 49) Restoration #4
i am new cant help you but can u tell me if your getting this message
   / Snowblower (Deere Model 49) Restoration #5
If it looks good, I would stop.
Mfreund, thanks for the reply. I did stop. She's 90% back together. And I took another look at the can, it's enamel, not paint. I don't know much about painting but assume that enamel is thicker? Makes sence now. So, everything got 2 coats of primer and 2 coats of enamel.
   / Snowblower (Deere Model 49) Restoration #7
That should be fine. Next spring, clean it up and check for chips and paint them. That's what I'm going to do with my blower that I just renewed.
How about some pics?
I do have a few pictures....I'll post them when I get home in a few hours. Thanks for the reply!!
First time posting pictures, hopefully this works. First one is a before shot. The rust was all through the inside.
Couple sand blast shots.
Primed.
All done!!
2005 CHEVROLET SILVERADO (A53843)
2005 CHEVROLET...
78'' root grapple (A53421)
78'' root grapple...
2016 INTERNATIONAL 4300 24FT BOX TRUCK (A54313)
2016 INTERNATIONAL...
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A53473)
2023 New Holland...
2018 MACK CHU613 DAYCAB (A53843)
2018 MACK CHU613...
