Snowblower dealers in MA?
   / Snowblower dealers in MA? #1
149owner
MA
Cub Cadet 149, Kubota BX2200, LX3310, JD LX277
Has anyone found and dealt with a 3ph snowblower dealer in MA that sells other the Kubota units? The closest Ber-vac dealer I found was in Maine and Pronovost was in NY or PA!. The 52" Ber-vac is $2600 and the Kubota is $2500. How do these compare to each other? The Ber-vac says recommended hp as 20-35 and their Blizzard 54" model says 16-35 hp but the BX2200's 3ph is rated at 14.5hp. It seems a lot of you are using these on a BX so should I be concerned with the hp ratings? Do these snowblowers work well with the slop we just got in MA or would I still have to clean up with a blade? Thanks.
Has anyone had luck using 12V actuators for chute rotation and deflector controls?
   / Snowblower dealers in MA? #2
The Noertheastern region dealer and stocking distributor for Pronovost is
www.tudorandjones.com
in Weedsport, New York
The Pronovost Puma Group one "snow thrower" is made of plate steel through out and will outlast your tractor
The P- 540 wieghs in at 550 pounds+- not including hydraulic cylinders for spout and chute if ordered.
The Pronovost snow throwers have full length welds and strong box construction.
You can purchase a Pronovost Group 1 P-540 directly from Tudor and Jones with no isssues other than either picking it up or having to unload it off a truck. You will be able to add the hydraulics later on if desired.
The Pronovost folks also offer a No. 2 P.T.O., shaft as an optional purchase for it as well.
The P-540 models 4 blade impeller is 22 inches in diameter and the impeller housing is nine inches deep.
The snow cutting hieght of the P-540 is 28 inches and the open auger diameter is 16 inches.
At 540 R.P.M. this snowthrower will cast
3.14 * 11*11*9=2 cubic feet of impeller housing volume (rounded higher)
using snow at 21 pounds oer cubic foot -f2 pounds of snow per revolution
of the impeller 540 revolutions times 42 pounds is 11 tons and 680 pounds per minute of use if filled to capacity which is 68 tons per hour(rounded lower).
The Pronovost snow thowers have basic components and are easy to maintain as they are built for canadian farmers and winters.
The roller chain is a standard item, the roller bearings are metric like all other bearings and available anywhere, the sprockets are standard issue size sprockets and you can find these parts locally.
The gear boxes are very strong in constructon where many gear boxes for implements are dual use for rototillers and snow blowers both typically.
If you buy a Pronovost P-540 from Tudor and Jones it will work for you season after season with no issues other than greasing, checking the oil level on the gearbox, oiling the drive chain for the auger and occasional painting.
The thicker steel used on the Pronovost P-540 and the welded tab corners and bracing where required prevents any flexing from occuring which will bind roller bearings and the augers on the kubota snow throwers which has occured.
You should look at the construction of the "snow thrower" before making any decisions if you want a rear mounted unit.
The parts for a Pronovost are not an issue as their snow throwers are built very well with plate steel and with parts that are obtainable locally if needed.
If you add one of clarences impeller kits for rear mount snow throwers you wont have any build up of slop and you just have to make sure the impeller drum is cleaned out before you put the snow thrower away.
   / Snowblower dealers in MA? #3
The BerVac, Blizzard and Kubota are all made by RAD...... who's quality is excellent.
Why not take nice drive up here and save yourself the government's cut ?
   / Snowblower dealers in MA? #4
We are in NY and have both makes in stock. My thoughts, Kubota is a Rad, You are looking at two of the best I've ever worked with.
The electric fails more then the hydraulic, which normally doesn't fail. Some say that the electric is only good for two years! We do see some going longer but moisture is the problem.
   / Snowblower dealers in MA? #5
just picked up a RAD blizzard 64inch at Kahn tractor in North Franklin CT last Saturday. Great implement, it is impressive. cost $2800, and was in stock. Don't know where in MA you are, but could be worth the trip. Great dealer in my opinion. It has manual angle adjust, but I adjusted the handle so I can easily reach it from my seat, it really is not an inconvenience at all. The power angle is just one more thing to break.
Thanks for all of the replies. I would love to be able to look at each manufacturer's model but no dealers in SE MA stock them and I don't have the time to travel to several states to see them all. That's why I appreciate all the help and info I've gathered on this site!
The P-540 says 18-25hp and the Puma 54 says 16-25hp. Will the BX2200 pto rated at 14.5hp handle one of those without putting too much stress on it? A 50" Farm King is rated for 15-30 hp. How does this one stack up against the Rad and Puma lines for construction?
Leonz, What is a No. 2 P.T.O. shaft and a clearences impeller kit? I'm kind of afraid to ask about the price of a P-540 since it is a commercial unit. How does the Puma line compare to it?
   / Snowblower dealers in MA? #7
I feel for you. SE MA dealers are far and few and most dont want to give the time of day. Where did you look so far.
Locally I've tried Goldstein's and Padula Bros. Morse is always full retail. Anyone out there with a BX2200 that has a snowblower with an advertised recommended PTO hp higher then 14.5? All other places I've contacted are over 2hr's away.
   / Snowblower dealers in MA? #9
The number 2 is the smallest size/diameter P.T.O., shaft available.
Clarences Impeller kit sweeps the impeller drum clear of snow and slush at every revolution of the impeller and allow for longer casting distances.
You can always buy a Puma 48, 54, 64, or 72 with its 22 inch diameter 7 inch deep impeller and and they all have the hydraulic chute rotation and spout control as standard equipment the impeller is 20 inches in diameter and six inches deep; the Puma 48 is 355 pounds compared to the P-540 being 550 pounds.
There are a lot of good blowers out there and some bad ones, but the issue is what you can afford; the smaller Pumas wieght less and of course cost less.
The build quality of the Puma 48 or the other Pumas is no different than any other piece of equipment that they build.
If you want to talk to someone call Ken Sweet as he is a forum sponsor or the Tudor and Jones folks on monday to get some more definite answers.
   / Snowblower dealers in MA? #10
Just to throw out some pricing up here in VT - the 54" Meteor sells at $1895 and the 54" Frontier at $2100. On the Deere site, there's a silly game you can play to get a $100 coupon for any Frontier implement over $500. So, for the $100 difference, there's no question in my mind that the Frontier is far better, given the quality of the build, paint and the more substantial steel. Not to mention the better resale should you find yourself switching out tractors or implements someday - on craigslist throughout northern New England, used Frontiers are priced higher.
I can't answer your question on the PTO issue, as the deere site doesn't list minimum hp requirements - only that it's compatible with their 2305 (at 18hp, I think?). If I were to guess, a 48" would be the better fit PTO-wise for your tractor - although, I don't know what your rear tread width measures out at.
   / Snowblower dealers in MA? #11
There's a thread going now titled, "how's everybody doing with the SNOW?" I noticed a couple of rear-mount blowers on BX and older B-series... you may want to send a private message to those guys to ask what they think, since they haven't responded to this thread yet.
   / Snowblower dealers in MA? #12
I am in Wareham. I have the front mounted 50" blower on the BX 2200 which works well for the most part. Has trouble with the slop that we have been getting down here but most have trouble with that stuff anyhow.
Have you tried Norfolk Power Equipment? They are pretty good to deal with I have found.
   / Snowblower dealers in MA? #13
Your biggest problem will be finding someone with one in stock. With this weather most are probably sold out
   / Snowblower dealers in MA? #14
If you dont mind a different color you can have an Allied from Ken Sweet, or a Puma shipped from Tudor and Jones in Weedsport, New York via Amtrak.
I think they still do crate shipping in the mail cars.
I wish I could be more help but I will suggest that you contact ken Sweet first shipping is weather dependent of course but an Amtrak freight load will get to you sooner from ken if the passenger service is on time barring weather.
   / Snowblower dealers in MA? #15
After this year's snows in Ct I am planning for upcoming winters trying to decide between a snow blower attachment for my BX-24 and a snowplow for my pickup truck. The BX 24 and its 63" snow plow were just not up to the task of my 1,500 foot driveway after two of the storms due to wind-blown drifts.
I'd appreciate any thoughts as to whether a front mounted snow blower for the BX24 would be a viable / lasting investment for me, or if I should think of something more robust.
Thanks in advance
   / Snowblower dealers in MA? #16
Thanks in advance
Its more than a matter of greater expense for a front mounted snow thrower.
You have an under body frame and you loose the opportunity to have a front end loader for other jobs during the winter.
You have the lower ground clearance issue to deal with and it limits your ability to cut back banks of snow AND a front mount is not really heavy enough for cutting back banks of frozen snow piles.
It would be simpler to purchase a rear mount snow blower and keep the blade as you can always dispose of snow piles with a rear mounted snow thrower.
just to illustrate what you are dealing with fresh snow fall is 21 pounds peer cubic foot and a freeze that increase the wieght per cubic foot of the snow fall.
Wind blown drift snow can wiegh more than 42 pounds per cubic foot.
If you have a one lane driveway that is 10 feet wide for the example and one half of it is filled two feet deep with blown snow in the example-
ten feet by seven hundred and fifty feet by 2 feet is 15000 cubic feet of snow and which would wiegh 21 pounds per cubic foot if it is fresh snow equalling 315,000 pounds 158 tons rounded higher for the drifted half adding the undrifted accummulation gives you 750 times 10 times one foot deep which is 75,000 pounds or 38 tons rounded higher and the total is 196 tons of snow to deal with in the example.
Using two hundred tons of snow as the example to be removed-
if you consider a Pronovost Puma model 64 snow thrower in the example which has twin hydraulics for the spout and chute offered as standard equipment.
it has a sixty four inch width of cut and a cutting height of 24 and one half inches.
The open cross auger diameter is 16 inches, the impeller drum diameter is 20 inches and six inches deep.
The rear mounted snow throwers impeller rotates at 540 R.P.M., the impeller drum volume is calculated as Pi *R*R*H
3.14* 10 *10 * 6 = 1,884 cubic inches slightly more than one cubic foot of volume and using 21 one pounds of snow volume per cubic foot in the example; 540 times one times 21 equals 11,340 pounds per minute slightly more than five and one half tons per minute of snow casting ability.
Using 2 miles an hour of travel speed in the example:
you are traveling at 176 feet per minute you would cover the 1,500 feet in reverse with the rear mounted snow thrower in 9 minutes (rounded higher for clarity,the return pass would add 9 minutes and the driveway would be cleared in slightly under twenty minutes at two miles per hour.
You have removed 200 tons of fresh snow fall in twenty minutes with 2 passes of the snow thrower using the previous example and left no snow banks.
All you would need is a pair of steering knobs for the wheel on the BX2400 and steer the tractor with less effort.
It would be easy to manage and the snow blower will not lose value as you could mount it on another tractor is desired with no loss in value.
A weatherproof fender mounted tractor radio would help pass the time while running the snow blower and it would make the job pass easier.
The thing you have remember for well constructed rear mount is that the auger should be able to draw all the snow in front of it with the auger and a front mounted snow blower will be limited as it may have to make several cut passes as the front auger is unable to do this with deep snows.
The front mounted snow thrower also typically has to be reversed in direction of rotation in many models to operate properly because of the mid mount power take off system.
I would contact Ken Sweet and enquire about the Allied Farm King snow throwers as he is a sponsor of the forum in good standing or Tudor and Jones in Weedsport, New York
and ask about the Pronovost Puma 64 snow thrower.
   / Snowblower dealers in MA? #17
After this year's snows in Ct I am planning for upcoming winters trying to decide between a snow blower attachment for my BX-24 and a snowplow for my pickup truck. ...
Thanks in advance
I own both. F350 with plow and BX23 with front blower. When you plow in the northeast you need to think ahead and push way off the road in the beginning of the season to have somewhere to put the later snow. When the ground is soft this can cause some damage until you are used to doing it. Also a lot depends on the area being plowed. If you will need to be doing backdragging etc or a lot of maneuvering or tight turns, plowing can be tedious
The BX with the front blower will send the snow 40' if you want it to. If you don't have a cab, you will learn to work with the wind. The blower will last just fine in my opinion if you are reasonable with it. One forgotten piece of firewood or rolled up newspaper and you will be replacing shear pins. In my opinion the front blower is the way to go if your kids or spouse will be expected to use it. A rear one is cheaper and allows for leaving on a bucket, and is easier to install/remove. I have filled ag tires on mine in the winter which is an excellent combination. I don't have any other counterweight other than the filled tires.
The truck is easier to transport, the blower makes the snow disappear. For me, at my home I usually use the blower, and I usually use the plow elsewhere.
Those are my thoughts. Good luck with your choice.
   / Snowblower dealers in MA? #19
Klems in Spencer is a new Holland dealer
Ahern in Spencer 1s a Kubota dealer I know tyhey do Blizzard
146 Supply in Millbury is a John Deere dealer.
Check what brands they sell in addition to their tractor franchises but all are in Central MA
How does a Puma compare to the Kubota rear mount?
2446 (A60432)
2446 (A60432)
2013 Felling Trailers T/A Side Dump Flatbed Trailer (A56857)
2013 Felling...
WOODS 9021 BATWING MOWER (A52707)
WOODS 9021 BATWING...
2018 CATERPILLAR 259D SKID STEER (A60429)
2018 CATERPILLAR...
2458 (A60432)
2458 (A60432)
2024 PRO FABRICATION RTM-5.2K-Y REEL TRAILER (A59905)
2024 PRO...
