Snowblower convertion
/ Snowblower convertion #1
wynsom3
Morinville Alberta Canada
Massey Ferguson B1260
Hey Guys
I have a Meteor SB60 3 pt snowblower with a 21 in. impeller and 60 in. wide that I would like to mount on a Bobcat S 130 with 16.9 GPM and 2750 PSI @ 3135 RPM ratings. I know there is something out there but be darn if I can find it. Does anyone have any experience with this kind of change over? I would like to blow the snow a fair distance and not just a few feet away. I saw a formula that took the DIA. of the impeller X the RPM X something else to give you some kind of idea how much snow you where gona move. Any suggestion or ideas would be greatly appreciated such as pump size ect. Thank You
/ Snowblower convertion #3
A quick hitch, some steel stock and a little welding would be a reasonable price for mounting. Look to the hydraulic forum for info on the hydraulic motor needed.
/ Snowblower convertion #4
a Buddy of mine did this, using a JD blower, I have used this and it works great blows snow around 40 feet. Just make sure you incorporate a shear pin and a pressure reducing valve in the pump drive. I know he blew a pump before he had it profected....:cool:
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
John Deere 302A 50HP Front Loader Utility Tractor (A61572)
John Deere 302A...
Challenger MT275B 40HP 4WD Utility Tractor w/ 76in. Rotary Brush Cutter Attachment (A59228)
Challenger MT275B...
832856 (A61166)
832856 (A61166)
2009 Cummins DGFA-5764071 150kW Standby Diesel Generator (A61572)
2009 Cummins...
2014 Ford F-550 Altec AT40M 40ft Material Handling Bucket Truck (A61568)
2014 Ford F-550...
