bdhsfz6
Elite Member
- Joined
- Apr 11, 2015
- Messages
- 3,074
- Location
- Northeastern Pennsylvania
- Tractor
- Kubota MX5800 HST & L6060 HSTC Formerly L6060 HST B7100 HST, L2550, L3010 HST, L3430 HST
I'm tired of the stiff neck I get every time I work in reverse to clear snow with my Woods SS74 3 pt snowblower. With that season rapidly approaching, I'm again trying to figure a way to mount the Woods on the FEL of my Kubota. It would be easy enough to weld it to a QA adapter plate and fit a hydraulic motor but powering it is the question.
Tapping into the main FEL hydraulic circuit is the way Kubota / Landpride and many aftermarket models power their units. I have heard complaints however about the loss of power to the FEL cylinders when the hydraulic motor is in operation. This would be a problem for me since I often adjust the blower height and angle due to uneven terrain. This means a diverter valve won't work so I'll have to add a spool valve. I was thinking of tapping the BH hydraulic circuit but I'm not sure this will solve the problem.
The only sure way to avoid loss of FEL power is to use a PTO powered pump but the cost would be too much. I'm willing to spring for a valve, hoses and a hyd. motor but beyond that, I'll just buy more aspirin for my stiff neck.
I'm curious if anyone here has attempted this project and if so, what were the problems / results, hyd. motor size etc. For those who have front mounted snowblowers, is the loss of FEL cylinder pressure really an issue?
