Snowblower and crushed rock driveway
   / Snowblower and crushed rock driveway #31
I used the largest diameter (I think that's 4" in the pics) that cleared the augurs - and I don't know if I could get a smaller diameter on.
The PVC in your picture says 2".
   / Snowblower and crushed rock driveway #34
I have thought about trying the pipe idea but when I consider how has a 5/8" thick cutting edge wears I have to wonder if schedule 40 pipe would make a season.
Think about how it would affect a narrow, sharp edge, vs. a rounded one.
There is no good reason to have a pipe, it if you have concrete, which wears it the fastest.
On gravel, or even asphalt, it's going to last.
Mine has been on there since 2007.
   / Snowblower and crushed rock driveway #35
Interesting, I'm on dirt and gravel and the cutting edge on my back blades or snow blades wears fairly quickly.
They are heavy blades.
   / Snowblower and crushed rock driveway #36
Get an ATV 4WD WITH A PLOW ON THE FRONT AND BACK DRAG THE SNOW TILL YOU GET A GOOD 3" HARD PACKED BASE.
WON'T HURT TO INSTALL TIRE CHAINS ALSO IF NEEDED.
PLUS YOU CAN MAKE EXTRA $$$$ PLOWING NEIGHBORS DRIVEWAYS.
GOOD LUCK THIS WINTER
An ATV is near useless. If I wanted snow pushed over 80 feet to be sure there’s enough space come spring I would have kept my plow guy at 50.00 per storm and not spent 10K on a blower.
   / Snowblower and crushed rock driveway #37
I have a "standard size" ATV. 700 cc - Yamaha. It's not near heavy enough to plow much snow. Unless you are talking 2" or less and for short runs.
My driveway is a mile long - gravel. I don't consider plowing unless - eight inches on the ground and it's still snowing hard. To do anything sooner - a waste of time and fuel.
My Kubota M6040 weighs 10,000 pounds and has a very heavy Rhino rear blade. When I DO plow - its fast and snow flies a good eight to ten feet off the driveway.
With these parameters I've not had to plow the driveway - even once - in the last four years.
However - I do plow out the mailbox area. Our mailman is a bit of a wimp.
   / Snowblower and crushed rock driveway #38
We certainly don't find an ATV "near useless". My neighbor plows our 1/4" mile hilly driveway with an ATV for any light to medium snows. In heavier storms, we'll use a tractor mounted plow or the snow blower on my tractor. The ATV by far sees the most use every winter: it gets the job done in a fraction of the time that the blower or tractor plow does. It won't handle the big storms, but that's what we have the bigger equipment for.
   / Snowblower and crushed rock driveway #39
We do our dead-end street and yard via atv. Might be 300ft worth. Not worthless to us!
   / Snowblower and crushed rock driveway #40
Welcome, but USING CAPS is considered YELLING. Most of us don't like it...
  • Good Post
Reactions: JJT
NEW Wolverine Skid Steer Auger Drive And Bit (A59000)
NEW Wolverine Skid...
20Ft. Bi-Parting Wrought Iron Gate (New/Unused) Galvanized + Powder Coated (A59225)
20Ft. Bi-Parting...
2015 MACK CXU613 (A58214)
2015 MACK CXU613...
2023 CHEVROLET 4500HD CAB AND CHASSIS (A58017)
2023 CHEVROLET...
2020 CAT 308 (A53317)
PALLET OF MOWER BLADES & MISC PARTS (A58374)
PALLET OF MOWER...
