Snowblower and ck20s? (not hst)
   / Snowblower and ck20s? (not hst) #11
I have a 54" on the rear of my CK20S HST. I use a 60" plow from Michigan Iron on the front. By the time I need to use the blower to widen my lane, I need the slowest speed I can get.
So, consider using the front mounted blade (faster than a blower) to make your initial clearing, and follow with one pass per side with the blower.
I have seen the front mounted blower, but between needing the mid-PTO and the additional bits to mount to the front, it was cheaper to buy the blade from MI and the rear mounted snowblower.
Good luck,
Jon
I'm kinda liking the idea of a pull type snow blower, I might see if I can find one at a reasonable price, I like that I can then keep the loader on which is useful for numerous reasons.
   / Snowblower and ck20s? (not hst) #13
Speed is a real factor with a snow blower in deep snow . I have a M5700 ( 50 plus pto hp. ) w/rear blower and had to have creeper gears installed in order to use it with my blower. This gives me 3 ranges w/12 speeds for reverse .It is in creeper mode most all winter when useing the blower . We do get some heavy snow in my area though .
   / Snowblower and ck20s? (not hst) #14
I have a Meteor pull type and really like it. I clear about 1 mile of driveways including mine and a couple of neighbours'. My neck would not be able to handle that with a rear push type. A front mount is also easy on the neck but more expensive and you lose the use of a loader.
As others have said, an HST is great for snow blowing.
2010 Hyundai Elantra Touring Sedan (A55853)
2010 Hyundai...
John Deere 2640 2WD Tractor with 146 Front Loader (A57024)
John Deere 2640...
2023 Polaris Ranger SP 4x4 Utility Cart (A55787)
2023 Polaris...
2007 Godwin Pumps GHP45KW-RC 45kW Towable Diesel Generator (A56857)
2007 Godwin Pumps...
Diamond C Trailers 26ft T/A Flatbed Tilt Trailer (A55787)
Diamond C Trailers...
UNUSED FUTURE 16" HYD AUGER (A52706)
UNUSED FUTURE 16"...
