Snowblower and ck20s? (not hst)
   / Snowblower and ck20s? (not hst) #11
I have a 54" on the rear of my CK20S HST. I use a 60" plow from Michigan Iron on the front. By the time I need to use the blower to widen my lane, I need the slowest speed I can get.
So, consider using the front mounted blade (faster than a blower) to make your initial clearing, and follow with one pass per side with the blower.
I have seen the front mounted blower, but between needing the mid-PTO and the additional bits to mount to the front, it was cheaper to buy the blade from MI and the rear mounted snowblower.
Good luck,
Jon
I'm kinda liking the idea of a pull type snow blower, I might see if I can find one at a reasonable price, I like that I can then keep the loader on which is useful for numerous reasons.
   / Snowblower and ck20s? (not hst) #13
Speed is a real factor with a snow blower in deep snow . I have a M5700 ( 50 plus pto hp. ) w/rear blower and had to have creeper gears installed in order to use it with my blower. This gives me 3 ranges w/12 speeds for reverse .It is in creeper mode most all winter when useing the blower . We do get some heavy snow in my area though .
   / Snowblower and ck20s? (not hst) #14
I have a Meteor pull type and really like it. I clear about 1 mile of driveways including mine and a couple of neighbours'. My neck would not be able to handle that with a rear push type. A front mount is also easy on the neck but more expensive and you lose the use of a loader.
As others have said, an HST is great for snow blowing.
2019 Dodge Charger Sedan (A55853)
2019 Dodge Charger...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55853)
2006 iDrive...
2014 Ford Fusion Sedan (A56859)
2014 Ford Fusion...
2015 Ford Taurus AWD Sedan (A55853)
2015 Ford Taurus...
ST205/75R15 Trailer Tires (A55787)
ST205/75R15...
HUSQVARNA RIDING MOWER 46IN DECK (A56859)
HUSQVARNA RIDING...
