Snowblower 2750D electric options
/ Snowblower 2750D electric options #1
douce48
CT
Kubota BX24
I was fortunate enough to pick up a used, but new looking, 2750D snowblower.
It has the electric chute rotation and discharge kit options mounted on the snowblower.
I need to get the directions and parts to run the power from the tractor (switches and wiring) to the snowblower electric options which have a 'snap connector' on each motor. I called Kubota and they told me to call a dealer. I went to my local dealer and they are having a hard time breaking down what's needed. He did find one drawing which showed one switch and wiring and it was around $90!
That's for just one electric motor hook-up.
> Does anyone have information on where to get the parts (other than Kubota) I need or the directions on how to hook this up?/B]
This should be off the shelf stuff but I need the directions or parts breakdown that comes with the electric kits.
My gut feel is when the dealer calls me back after contacting Kubota, it's going to be around $200 for everything :mad:. I don't mind buying quality but that's insane for two toggle switches and wiring (they must be painted orange).
Thanks in advance for any help,
Douce
/ Snowblower 2750D electric options #2
If you want Orange it'll cost ya but if you want to do it yourself you'll need two DPDT toggle switches, a fuse and holder, some wire, and connectors. You can try NAPA for the motor connectors, they seem to be door window motors, but you could use whatever you want getting M&F and soldering into the motor plugs. Wire from the battery positive to the fuseholder to a center pin on each of the toggle switches. Wire from battery negative to the other center pin on each toggle switch. One switch will run the chute the other the rotator. Run wires from the motors to one set of switch pins and then cross them to the remaining set of pins such that the power is applied one polarity in one position and reverse polarity in the other resulting in up/down or left/right motions.
Enjoy your new snowblower!
/ Snowblower 2750D electric options #3
I added the electrics to my snowblower. I put the controls in a box. Wired the motors to a plastic J-Box and used a waterproof connector to connect the two. This makes it easy to remove the blower in off season. I tapped power from the fuse block and terminated at an automotive type connector as can be seen.
Took a day to do, but has been a good setup.
paul
/ Snowblower 2750D electric options #4
Yep!
DPDT center OFF spring loaded toggle switch. ($10.00)
50 Amp Anderson connectors ($12.00)
Fuse holders, 12 guage wire ($5.00)
/ Snowblower 2750D electric options #5
They use a window motor...... no need to spend the big bux on Kubota parts.
/ Snowblower 2750D electric options #6
I got both electric drives on ebay for about $ 100 total, including Kubota install kits.
paul
Thanks for all the information!
Will I be able to find the 'snap' connector mates that I need to connect to the motors locally or will I have to cut the motor lead connector off and splice on new snap connectors?
I'm sure I could find male and female connectors if I was creating a whole new electrical lead but I'm not sure what Kubota used and whether I could find the 'mate' connector. I hope I made sense.
Thanks again for your help. This forum is priceless.
Douce
500 BBL WHEELED FRAC TANK (A58214)
500 BBL WHEELED...
2018 Toro Z-Master 6000 Series 74in Zero Turn Commercial Mower (A59228)
2018 Toro Z-Master...
2022 Horizon (A55973)
2012 COMPTANK ACID TRANSPORT TRAILER (A55745)
2012 COMPTANK ACID...
2007 Jeep Liberty 4x4 SUV (A59231)
2007 Jeep Liberty...
2014 Chrysler 200 Sedan (A59231)
2014 Chrysler 200...
