Snowblade treatments?
   / Snowblade treatments? #1
Sierraau
Truckee, CA
2019 Rx7320
Are there any new and improved products you can put on your metal blades to keep the snow from sticking? I've tried the sprays, I even took a weed burning torch and melted wax on the blade, but everything I've tried only lasts a few minutes. Was wondering what anyone uses to keep sierra cement from sticking to their blades? On my front plow, I put sheets of 1/4" HDPE screwed to the blade and they seem to work pretty good, but my rear blade I can't use those as they will instantly get torn off.
   / Snowblade treatments? #2
I use a product called ProtectAll, which is a spray on wax marketed mostly to RV folks. Spray it on, smear it around, wipe with dry cloth if desired... Otherwise it dries clear.
I never really tested to see how long the coating helped, but it does shed snow well for one plow run doing 15 or so long rural driveways. It's so quick to apply that I just use it prior to each snow event.
It also works great on the cab glass and mirrors. (once per season).
   / Snowblade treatments? #3
Could you post a link to the specific product you’ve been using ?
Tried searching Amazon but there seems to be all kinds of different products using the ProtectAll name.
   / Snowblade treatments? #4
This is the stuff... Walmarts carry it in the RV section also.
I also use it on plastics, rubber, glass, and paint.
Protect All 62016 All-Surface Care Cleaner, Wax, Polisher and Protector - Interior and exterior use, 16 fl.oz. Amazon.com: Protect All 62016 All-Surface Care Cleaner, Wax, Polisher and Protector - Interior and exterior use, 16 fl.oz. : Automotive
2017 Ford F-250 (A55973)
2017 Ford F-250...
2088 Chevrolet C7500 Altec TA40 41ft. Bucket Truck (A59230)
2088 Chevrolet...
2012 VOLVO A40F OFF ROAD DUMP TRUCK (A60429)
2012 VOLVO A40F...
2022 CATERPILLAR D3 CRAWLER DOZER (A60429)
2022 CATERPILLAR...
Hydraulic Liftgate (A59230)
Hydraulic Liftgate...
SET OF PALADIN JRB 60" PALLET FORKS (A52707)
SET OF PALADIN JRB...
