SNOW
   / SNOW #1
CBB
Just north of the PA line in NY
JD 5320N Vineyard, 1981 Deere 910, 1980 Kubota B22, 1983 Ford 1710
My concerns about snow plowing have been put to rest. I have the CK20 with V-Bar chains on the front tires and Rim Guard for weight in all four industrial tires. The tractor has a heated Sims cab, scraper blade on the back and 54” bucket on the front.
Our neighbor has a bigger Kubota with out chains or weight in the tires and ag. Tires and that tractor was worthless in the winter for plowing. Slipped everywhere, just terrible. I was afraid the CK20 might be the same but it is great.
   / SNOW #2
Evening CBB.
Its good to get the little things figure out before ole man winter dumps heavy loads...plow on.
Kubota..."Tires and that tractor was worthless in the winter for plowing. Slipped everywhere, just terrible."...be interesting to know the circumstances what cause the problem...worn tires,wrong range for snow removing etc...
   / SNOW #3
That heated cab sure is nice in the winter, aint it? ;)
   / SNOW
Thomas said:
Evening CBB.
Good question. This is a very old Kubota with one of the first Woods front loaders. The reason it was bad is that it had no weight in the front, good tires but no chains and no weight in the tires. We always used the JD 990 with chains to do the plowing for ours and four other homes. When the JD went into the shop last winter, we borrowed the usually parked in the winter Kubota and that is how we learned to appreciate weights on the front of a tractor, loaded tires and chains. It is really not so much that this tractor is Kubota as it is just not properly outfitted for the job we want to do with it. I will say we have three Kubotas on the hill, one JD, one Ford and one Kioti. The little Kubota is bullet proof...it is like a 2200 or something...so old the numbers are gone but it starts right up and works great but is used only 5-6 times a year for specialty jobs. The other two Kubotas are a real pain. Just endless problems that I am not going to detail. The JD is good. Had some problems last year because my Dad uses reservation gas and it tends to have some water in it...more than fuel additives would fix but I fixed that by siphoning and now have a tank for the tractors and that diesel is better quality and has no tax and so is cheaper by 30 plus cents a gallon over the reservation. The old Ford is like a stallion out to pasture...mostly parked but great for hauling a wood wagon and brush hogging. The Kioti is a really nice tool. It will fit down the row for spraying, is a heated cab and works well. I just did the driveway with a sweatshirt on in 20 degree temps and was toasty and actually enjoyed the job.
Those v-bar chains are most excellent.
I will get some pictures of some fun mods I have been making on the tractor but that is for another post.
   / SNOW
Hey Derek,
I was at the Friday fish fry a few hours ago with my neighbors and we got to talking tractors and all the ole timers went on about how they like the cold and snow and how they just put a mask hat on if it really cold. I smiled and did not comment but I suspect they will change their tunes in no time. Some of these Southern WNY winter days and nights can be pretty fierce.
Yes. That heated cab is very nice!
   / SNOW #6
I had the cold and snow in my face the last few days. The CK30hst pushes snow fine, it just gets a little cold. Maybe I should think about a heated cab. :)
Or maybe not. The wife feels so bad for me when I come in that she has a hot cup of tea ready and asks me if I want anything else. A heated cab would ruin all that. :)
   / SNOW #7
Hard on the drive train not recommended.
Been several post about this.
   / SNOW #8
I am not a fan of snow but am a bit curious to see how the 45 cab does in the white stuff. I have ag tires and loaded rears, no chains but never really needed the chains for my JD 870 and it had turf tires but I had to plow down the driveway. CBB, it sounds like you have a neat setup.
   / SNOW #9
Oleozz, A friend has a 45 cab without loaded rears and plows his 1/4 mile driveway using a 7 ft. backblade. It has R4 tires and he doesn't have a problem even with a foot or more of snow. I think yours will do fine unless you get on ice, which all tractors have problems without chains but I can usually get at least one tire on good ground. My CK30hst does fine with R4s not loaded and no chains. Have fun this winter if you haven't had all ready. A foot was dumped in two days last week and I got some seat time.
   / SNOW
Thanks for the post. I did some checking, read the posts and then made the decision to buy the front chains. I think it will be fine but if not, sure will make a post about it.
2016 KOMATSU D61PXI-23 CRAWLER DOZER (A51246)
2016 KOMATSU...
2017 Ford 550 XL, Cab and Chassis, Crew Cab (A52384)
2017 Ford 550 XL...
HOMEMADE 4' X 12' SINGLE AXLE TRAILER (A51248)
HOMEMADE 4' X 12'...
Toro Mower (A50324)
Toro Mower (A50324)
SKYJACK SJIII 3219 ELECTRIC SCISSOR LIFT (A51246)
SKYJACK SJIII 3219...
