Snow tractor
/ Snow tractor #21
Not to beat a dead horse ;-) agricultural tires go just as poorly on hard pack snow and ice the only time the agricultural tires are better is in the mud because they don't pack up with earth from personal observation of using both tires on the farm. By the end of February around here most of the roadways and backyard skim over to ice I chain up. I would agree agricultural tires are good in deep snow when you have to get into the field to get the round hay bales my 2420 has gotten stuck a few times I am talking deep snow over the front tires and quite a hill, but when using a tractor with the snowblower or front plow there really is no issue of driving in deep snow. Take care
/ Snow tractor #23
Surprised that you are not stuck running those R4 tires. guess you did not know that you cannot use them in snow.
Funny, I've never had a problem with R4's doing snow removal. Tires not loaded either. Get in deep enough and anything will get stuck.
/ Snow tractor #25
you guys down south are too lucky, you get to have as much if not more white stuff than us way up north and your summers are blessed with rattlers, scorpions and venomous spiders ;)
/ Snow tractor #26
Yea its amazing we just are not use to it.
/ Snow tractor #27
I am considering chains for my 3130 with loaded R-4's. Tractor is totally useless on my sometimes icey hilly paved driveway. I don't use it for snow removal but I would like to use it for clean-up once in awhile. Like now because we just had 24" of snow.
Can anyone out there suggest type, cost and where to buy chains for my tractor.
/ Snow tractor #28
yeah,....I want to know about chains now too! It took me 6 hours to clear the two feet of snow we got, I never thought that it would take that long. I got stuck 7 times! aauuuuuggg! the snow was just the right moisture to turn to hard pack ice after going over it once, which also meant that you can't push it far before it turns into a 6 foot tall pile of granite on you. Running with the rear blade on an angle doesn't get you far in that stuff, once the blade starts to ride up you are done. The blade just turns into an anchor because you can't lift it up high enough to get out. I have a friend with the same machine except he has a snow blower for the front I know I will be hearing how great it worked for him any day now.
/ Snow tractor #29
Sorry to hear about your troubles but I do like your write up. 2 feet of snow things change.....a lot.
/ Snow tractor #30
Here's my snow removal rig...
I have problems with the R4s after I've started plowing and the little remaining snow skims over the asphalt turning to hard pack or ice, then the front tires slide all over. Most of the time when I need to chain up, I can get away with front chains only. Front and rear chains, and there's absolutely no stopping me, but I don't think I've chained up the rears in 2 years. Haven't chained up the fronts yet this year, but I'm sure I'll need to eventually.
If I recall correctly, I got my chains from www.tirechains.com
/ Snow tractor #31
I'm in the Great White North (Ottawa) and we have about the same amount of snow on the ground as in your photo. Mind, it's -12c today (something like 10-15 F) so it's Brass Monkey cold ;)
2015 Polaris Sportsman 570 AWD ATV (A64557)
2015 Polaris...
Warren Power Systems WCW204MH 20KW Towable Light Tower (A64194)
Warren Power...
Landhonor Adjustable Rolling Creeper Stool (A66408)
Landhonor...
60in. Work Bench (A65640)
60in. Work Bench...
FRONTIER HYD BALE SQUEEZE (A64277)
FRONTIER HYD BALE...
215603 (A63276)
215603 (A63276)
