Snow removal with grader blade
   / Snow removal with grader blade #11
I had a local shop weld on some brackets so I could attach plow shoes.
I did this because the blade was just taking a beating when getting caught on the protruding rocks that were frozen into the ground. This helped a lot, now of course as it thaws the blade is so heavy that it pushes the shoes into the ground. Although the shoes were homemade and don't have enough surface area. See attached pic.
This year we will be adding thousands of dollars worth of gravel to our 1/2 mile driveway and I'll need something that doesn't push all my gravel into the ditch.... may be time for a blower attachment.
   / Snow removal with grader blade #12
I did pretty much exactly what Tvanharp did with his blade. I made the skids about 4.5 inches in diameter and dished them with a hydraulic press.
Adjustment with washers, and they work quite well. Mine come off in the summer, the pipes they run up and down in are above the grader blade cutting edge so they don't interfere with dirt work. Not the best photo, I'll try to get a close-up if you're interested.
Sean
   / Snow removal with grader blade #13
Today I picked up my order of skid shoes for the Frontier RB1072 AKA Woods RB72. They are 6" across. Hoping to use them on the gravel driveway without removing gravel.
Got to say these things are beeefy. I think they are 25lbs a piece.
I plan on taking a few photos tomorrow for posting, before installing them
   / Snow removal with grader blade #14
If you get everything just right, rear blades work great for clearing snow. Although a person would probably be in trouble if the snow was to deep.
   / Snow removal with grader blade #15
sierradmax said:
This past week, we encountered taste of winter for the first time since purchasing my B2320. We got around 5-6" of snow and unfortunately, the ground wasn't frozen. My home consists of a large driveway with 3/4" crushed stone. I was concerned about snow removal and purchased a 72" grader blade from Tractor Supply. I had read online and viewed videos of tractors using them for snow removal but this week as my first time out, I made a mess of my driveway. Granted the ground wasn't frozen.
I tried keeping the blade elevated a little but my driveway isn't entirely level and the first depression sent the blade pulling stone. Are there any tips? I had used a front mounted plow on an atv previously and it worked well. Should I weld skids on the rear of the blade?
That's pretty wide for a b2320
I've got b2920 with a 60" blade with front mount blower (400+lbs) and traction is an issue at times
Good luck
   / Snow removal with grader blade #16
MVR, does your rear blade swing left to right..?? or is it an optical illusion
   / Snow removal with grader blade #17
Here is a picture of my skid shoe that I am getting ready to install. They were ordered for my Frontier RB1072, AKA Woods RB72.
They are quite beefy weighing in at 36lbs each.
   / Snow removal with grader blade #18
Not sure that I understand your question? :confused3: All rear blades swing left and right. My boom will offset up to 35" to the left and right which I guess is what you are asking, but in the picture the boom is straight back and the picture is an optical illusion. A lot of my grading or plowing pictures are just me holding the camera and snapping an action shot. So the camera is not always in the best position when the picture is taken. :eek: ;)
   / Snow removal with grader blade #19
Yep, that's what I was looking at...
I don't have a grader blade yet but pondering......hmmmm pondering......:drool:
   / Snow removal with grader blade #20
When you do get one, you may want to check if you can easily add hydraulic angle as a minimum requirement.. although I probably don't have to tell you that anyway. Of the modifications I've made to mine, that is the single best one so far.
Anytime I use the blade I find myself wanting to fine tune the blade angle, it's a lot easier to do that from the operator's seat than getting off every time. Particularly for moving snow, the less I get on and off the tractor the better when it's icy underfoot.
Sean
John Deere 6120M (A57148)
John Deere 6120M...
1997 DORSEY AIDT-LSCG 53 FT DRY VAN TRAILER (A59575)
1997 DORSEY...
2019 MACK GRANITE (A58214)
2019 MACK GRANITE...
Compact Track Loader Skid Steer (A59228)
Compact Track...
2010 CHEVY SILVERADO 3500 HD PICK UP TRUCK (A59575)
2010 CHEVY...
1994 Chevy 2500 Pick Up (A59814)
1994 Chevy 2500...
