Snow Equipment Owning/Operating Snow Removal tires
   / Snow Removal tires #11
I HAD R-4S FOR 4 YEARS JUST CHANGED TO TURFS SOILD FILLED NIGHT AND DAY DIFFERNCE LOVE THE TURFS
In your case, I bet having the tires filled has more to do with your increase in traction than the tire tread itself. I had my previous Ford backhoe as a snow removal piece for years. One year I decided to fill the rear tires and it made a big difference.
Also, new tires have nice sharp square edges that really bite (in a good way) in snow & ice.
   / Snow Removal tires #12
Having moved south from PA, snow plowing is not an option anymore though that may change this week? Seriously, chains come to mind.
   / Snow Removal tires #13
It depends. In ice, anything with chains. It really doesn't matter tire type as long as the chains are kept on the surface. In snow, the R1's paddle much better. Weight makes as much difference as about anything. Also, I like a narrow tire in both ice and snow.
   / Snow Removal tires #14
I just switched from turfs to ag tires this past year. I was going to put the chains on and decided to try it with out them. I believe that in snow my ag tires are a lot better then my turfs with chains. In icy conditions any tire with chains is better then no chains. I really hate to use chains if I don't have to. I had one come loose several years ago as I was spinning and did alot of damage to my rear fender. I have never liked them since.
   / Snow Removal tires #16
It's amazing the differences of opinions we've seen on this topic, which has been exhaustively discussed for years in dozens of threads on this website.
I think too much is put into defending one's tire choice and not enough emphasis put into the fact that everyone has different conditions in which they plow snow.
   / Snow Removal tires #17
I use the goodyear extra trac tire( wide like turf tire but has a less agressive bar than a r4 or r1 ag tire) with chains. with a front mounted 5' snowblower. I like them as I feel that I get the best footprint where thr rubber meets the road or snow as it were) with them. also I have about 200# weight on each wheel with wheels set as far apart as posible on my B7510 HST. I live in north western PA 30 miles south of lake Erie in the heart of the snow belt with about 225 inchs of snow this winter and counting! If ya live here you gotta love it!
   / Snow Removal tires #18
Turf tires work just fine. I use a back blade & the FEL on a JD 970. I have chains for it but actually took them off this winter because I just didn't need them except one time when I had to negotiate glare ice on a hill. Even then I was able to get up the hill without chains, but not with the back blade dug in.
   / Snow Removal tires #19
What do you prefer? I am currently using turf tires with great success, but wondered what everyone prefers with FEL, snow pusher, or plow usage.
With a search you might have noticed there was already at least 13 threads, with about 300 posts on this subject.
   / Snow Removal tires #20
My opinion based on my own observations. Turf tires work really well on a paved surface in snow that is less than 6 inches deep. In deep snow or on gravel or grass, ags will work best, and R4's better than turfs. On ice, turfs will work best but still be really lousy, chains will be best on ice.
2016 CATERPILLAR TL642D TELESCOPIC FORKLIFT (A52709)
2016 CATERPILLAR...
2021 Ford F-150 4x4 Ext. Cab Pickup Truck (A54814)
2021 Ford F-150...
JOHN DEERE 7210R TRACTOR (A54756)
JOHN DEERE 7210R...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2018 Ford F-150...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
2018 Toro Reel Master 5510-D Fairway Reel Commercial Mower (A56857)
2018 Toro Reel...
