Snow Snow removal options
/ Snow removal options #41
If you have a skid steer quick connect front end then I would say that getting a quick attach plow is a good option. I built my own and clear most of the snow with the blade, switch to the bucket to move and pile snow higher and I am done. I have about $600 into the plow setup including buying a user meyer blade. I will post pics of setup
/ Snow removal options #42
Hi carl bert
I think you have close to ideal setup for snow I would get a mid duty 5-6' blade for the 1 to 8" snows forward use your new blower for heavier widen drive and the FEL to clean snot at end of drive from gov as well as close in work. dress warm ski goggles etc
PR
/ Snow removal options #43
For my 900' gravel drive I went with front and rear homemade blades. If needed the front comes off in few min and the FEL goes on in the same amount time. Worked great this past winter and for under $200 for both think I hit it.
http://oi46.tinypic.com/2150s34.jpg
/ Snow removal options #46
My snow plowing learning progression:
For many years I got by with an ATV and a blade. Three years ago we moved in to the country that is flat as a pancake. The first two years the ATV and plow did fine. Last year it was 12" of snow and 25MPH winds. This equals 4' snow drifts. An ATV with a blade against 4' snow drifts just isn't a fair fight. So I get out the tractor and FEL. This worked much better than the ATV and blade but the tractor with R4's, even on level ground in 4WD, could barely push it's own weight. Much less with the loader on the ground. So this year I bought the meanest set of tractor snow chains that I could find. I have learned that there can be so much snow, drifted so high, that no blade can take care of it no matter what it is attached to short of a bulldozer. The snow has to be physically moved and not pushed. Either by FEL or snow blower.
/ Snow removal options #47
I have R4s and bought chains last year after getting fed up with the ice. They make a BIG difference. Yeah with 4 foot drifts it's blower time.
/ Snow removal options #49
I'm having trouble seeing why chains make such a difference - doesn't the metal just slip on the ice?
Good morning,
I can tell you the metal does not slip as long as you have ballast in the tires on ice or good dry traction.
/ Snow removal options #50
Here's my set up with a b26,64" rear blower and a laurin cab with heat...now when I turn my tractor on.it does return the favour .... IMG_2431.JPG
/ Snow removal options #51
Welcome winter,and a belated Merry Christmas and a happy new year also to all..
Just a recap on snow set ups...people were wondering about the b26 and the 64" rear blower...well it does bog down when going too fast through deep snow..but it handles it very smoothly and awesome...honestly who snow blows at 10 miles an hr any how....no ballast or chains or spacers...haven't got stuck yet! ( knock on wood ) ...with laurin cab and 64" kubota blower..is awesome and it handles snow quite well..people wanting and wondering if they should put rear blower on b26 please do..I recommend it..as for cramping neck by looking backwards easy fix..get side mirrors put on and adjust accordingly,.trial and error will get it all set right...where one would just use mirrors ....so on short b26,64" rear blower is awesome and handles it all...I do suggest if you got the means..laurin cab is the best....
/ Snow removal options #52
This is my first year with the B2650 and blower (64" like yours). I had no idea what to expect, with a 1000' gravel drive and huge parking areas, I had read all the stories of going through many shear pins.
We have had 3 measurable snowfalls so far, 2 of them (including the one I cleaned up yesterday) were wet heavy slushy and not nice to deal with. The blower and tractor (on turfs) performed flawlessly. No shear pins lost. Threw the wet snow like a champ.
Now I really baby my equipment, so I was going very slow taking my time, but so far I have zero complaints about my setup!20171210_101724.jpg
/ Snow removal options #53
Now I really baby my equipment, so I was going very slow taking my time, but so far I have zero complaints about my setup!View attachment 534650
Very nice setup , Nice and toasty warm :thumbsup:
/ Snow removal options #55
I don't get it. If I can use a grading blade, without a problem, then why would a rear mounted pull snowblower be a problem? With both implements you need to drive through the snow, with the tractor, in order to use them. I don't get it.
No, you don't need to always drive through the snow to use a rear blade.
This was a 7 year old thread until the last few posts. The OP, Carl Bert, has not been back on this thread anyway since 2010 (!) Surely by now (in 7 years) he has long since done something. Why don't you come back and tell us what you did enlightened by the last 7 years ?
Since the thread obviously has taken on a life of its' own in early 2018 (topic getting popular every year when there is an attention-getting winter) I'll throw in more opinion.
1) With 100' blacktopped driveway you really don't "need" anything but the FEL you have (or had.)
2) Cheapest easiest addition is the rear blade. You do not have to run over snow using it -- turn it around and plow backwards. The idea is not that plowing is reverse is such a great idea but rather with that simple cheap addition you can "work both ways" shoving with the FEL one way and pushing it in reverse the other way. No deadheading and no turning around. Also the FEL and rear blade complement each other in what they are best at.
3) The GX345 was never a good idea for snow removal when you have (had) a Kubota BX around. The GX345 is around 6 to 700lbs. -- 1000 lb lighter. Weight matters. Traction and investment sense also matter.
4) Any front mount blower is a whole bunch more effort to put on and take off than a simple blade. Worse yet you have to give up the FEL to use the front blower. No way ! Simplicity usually whips complexity. And unless you just "want one" you can't justify a blower on a 100' drive unless maybe a walk-behind for clean up and trim purposes.
5) You probably get 3x the snow we do down here in So MD. But, to the extent any of this is still "current" you might be interested in what I did with a BX2200 and a 100' blacktop driveway. I usually do a dozen driveways when we have snowfall over 8 or 10 inches. Plus opening at least a dozen driveways after the ultra-helpful County has covered up our driveway entrances and mailboxes with 5x the depth of snow that was in the natural snowfall.
With those excuses, I found a beat up old used bucket (still very serviceable, not full of holes or rust damage) for $100 at auction; around 50% larger than the BX std bucket. Moves a LOT more snow per pass. I had a local Amish welding shop adapt the old bucket to fit the mount on my BX loader frame by putting some new mounting holes on the bucket. ($100) The welding shop also had some 1/2" thick hard plastic scrap (do not know if it is ultra high density super stuff or not.) I had him cut me 4 "skids" around 3" wide and a foot long for the bottom of the bigger bucket. I bolted those on using carriage bolts so i could minimize the heads sticking out. A few cans of black spray paint and minor grinding and wire brushing for looks. Total project under $250.
2016 Land Rover Discovery Sport 4WD SUV (A61569)
2016 Land Rover...
NISSAN FORKLIFT (INOPERABLE) (A60736)
NISSAN FORKLIFT...
2011 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A60736)
2011 DRAGON 150...
TULSA WINCH (A60736)
2022 Vermeer 573 (A55973)
2022 Vermeer 573...
2018 Ford Taurus Sedan (A61569)
2018 Ford Taurus...
