Snow removal and dead tractor - looking for manuals CK4010chse
   / Snow removal and dead tractor - looking for manuals CK4010chse #11
Psst….or this similar type of issue in a thread close to yours.
   / Snow removal and dead tractor - looking for manuals CK4010chse #12
Main fuse in harness or fuse link, or relay. You said you could smell some thing chances are some thing electrical was get hot.
Double check your battery connections. Maybe a cable needs to be reattached or is corroded.
THe connections are fine and not corroded at all. Very clean really.
THanks
THanks! This look promising.
ok, I looked at everything today for any sign of problems with connections and relays, but everything looks clean. I will try and attach pics/video of the engine, etc.
After looking at everything (I did nothing to the engine other than move the red connection cover on the solenoid (I think that is what it is) and the connection looked fine, I tried to start it again. I have it on video as I was trying to capture the sounds it made from yesterday.
And again, no lights or sound when I turned the key to auxillary and the spot before trying to start it (generally where the engine warms up the glow plugs for a bit), then I turned the key to start and the tractor started!!
It did have a warning light this time though (check engine light).
Should I take it to a kioti mechanic? I certainly am not a mechanic and it did not show a warning light in relation to any electrical items or battery.
THanks
2020 MACK GR64FT (A58214)
2020 MACK GR64FT...
John Deere 5105M (A53317)
John Deere 5105M...
Jack Daniels Tennessee Whiskey Sign (A57454)
Jack Daniels...
(31) Concrete Pins (A57454)
(31) Concrete Pins...
(4) Ratchet Straps (A57453)
(4) Ratchet Straps...
2018 FREIGHTLINER M2 26FT BOX TRUCK (A59575)
2018 FREIGHTLINER...
