snow pusher vs. rear 3pt blower
   / snow pusher vs. rear 3pt blower #11
My back (degenerative disk disease) wont allow me to twist around backwards to watch the blower and where I am going, so I got me a front mount blower. It is the very best thing since sliced bread.
   / snow pusher vs. rear 3pt blower #12
I made side extensions for the FEL to use it as a pusher. They attach with one bolt each, so it's easy on and off. Picked up a used 64" Pronovost rear blower and wired up a linear actuator and car seat motor for cthe chute control instead of adding remotes. It all works well, but without the cab it wouldn't be as much fun.
That's really a great set of ideas with the seat motor used for low force applications that do not justify a hydraulic remote. Good stuff.
About the blower vs pusher: Since he mentions a bucket, it seems like totouchantler has a FEL. I use a Kubota B2150 with FEL and 5ft blower on the back with an option to put a blade on the back too. (This in ski country mountains where snowfall over a foot is common several times a season.) That way I can move snow with the FEL going one direction and blow it (or blade it) going the other direction which makes the overall removal job much faster and easier. One comment mentioned driveway damage -- if the snowblower is tilted up just right using the top link it will neither damage the driveway nor ingest gravel. Takes some cut and try. Especially if you have the FEL -- my goodness YES, get a 3pt blower. There are many choices on the market and many available used too.
   / snow pusher vs. rear 3pt blower #13
If you have a SSQA on your FEL then plow up front 3 point snow blower on rear, then there's not much that can stop you. I us a HLA 2000 hydro Plow 84" up front and a Land Pride 3584 rear blade on the 3 point but when snow falls are 12" and over back blade comes off and 74" three point snow blower goes on. Believe me when I say I have tried all , Jeep with plow, F350 Diesel with 4 way Fisher Plow, Grand L as I said works the best just make sure you have your Carharts on, Lol.
DevilDog
   / snow pusher vs. rear 3pt blower #14
DevilDog
+1.
I'm running a 9' Western power angle snow plow on the front (SSQA) and a 3 point snow blower on the rear, chains on all 4 tires.
Awesome setup for me.
   / snow pusher vs. rear 3pt blower #15
DevilDog
Sounds like the man with the experience. I think your L3901 should handle a 6ft blower real well. You didn't say if the 3901 is an HST or stick. I find that the creeper gear is VERY helpful in using a snowblower on my B2150. Normal gearing is really too fast for everything but the very light or fresh snow cases. If you have HST that is probably better yet, allowing you to keep the rpms up but travel slowly.
   / snow pusher vs. rear 3pt blower #16
Here's my situation... I just bought a Kubota L3901. It snows where I live... and I mean snows (150 inches average!) Straight across from my driveway after the shoulder is quite a nice little drop off (Ill explain later). My question: Should I buy a snow pusher or a rear mount blower. Now for the pros and cons (as i see them). Pro for blower. I will never run out of room for putting snow on either side of driveway which is blacktop, my bucket would be freed up for moving banks back, etc.. Cons for blower: It is very windy on the hill I live on (open work station snow blowing everywhere as it is), having to drive in reverse, having to add extra rear remotes at quite a good cost :mad:. Cons for pusher: because it doesn't have a bottom I don't feel like I can pick and move banks back, bucket is off machine, etc. Pros for pusher: Cheaper to buy, rubber scraper easier on driveway, I have that drop off across street to push snow off. What do you all think. Just trying to ask question snow so I can be ready to go by next winter. Ugh...winter.
Chris
Blower, pushing just makes banks which makes drifting in even worse.
   / snow pusher vs. rear 3pt blower #17
I always got a kick out some arguments about needing the FEL bucket to move the banks back when they buy a rear blower. With my rear blower, there are no banks to move, ever. Even if you blow the snow into an area you didn't mean to, is is very easy to move it again.
I have both the rear blower and a FEL power angle snowplow. I only use the plow on 4" or less. Otherwise the blower hits it once & it is gone for good. I will never own a tractor without the blower. Now front mounted vs rear is a discussion for another thread.
   / snow pusher vs. rear 3pt blower #18
I have every piece of snow removal equipment... Except a blower. I have a 8' snow box that I use with my skidsteer and it works well. Also have a 8' SSQA plow blade that works well. My .02 is that your tractor will not like moving a pusher full of snow because of the weight. If you are only moving 2-4" at a time it will be fine. A blower in a open station would be miserable for me if it's windy. Last year I bought a 9'6" V plow that I absolutely love. I understand what you are saying about having a drop off at the edges of your driveway. I do as well. 2 winters ago we got 130" of snow and I used the Skid with the pusher to move snow into our drop offs. The snow was piles almost 15' deep. But my skid has tracks and floated on top of the pile. My tracy or with tires would likely sink in. ...either option beats the shovel.
   / snow pusher vs. rear 3pt blower #19
I have a L3200, more or less identical to yours & live in Colorado.
I built a SSQA truck plow using a smaller lighter plow I got for $100. Think it came off a smaller Jeep. I also had a 72" LandPride back blade I have since sold. It was less convenient, but otherwise performed about the same.
At any rate I have ran into several snows here in Colorado I couldn't drive through, much less plow through. I now have a 3pt 60" blower.
I plow 80% of the time as its faster, easier & sprays less snow in my face (have to blow into the wind at times). But when my plow fails me I'm happy to do a U turn & fire up the blower.
I don't think a pusher would work well at all. My machine doesn't have enough weight to push a lot of snow. A plow rolls it to the side so you aren't pushing nearly as much weight.
   / snow pusher vs. rear 3pt blower #20
Reading Fallon's post above, I couldn't agree more, or have said it better. I have an open station tractor, as well, and just can't picture using a blower unless the wind was at my back. We have a 78" plow, and combined with the loader, it works pretty well. When I have deep snow, and need to push it up and over a pile, the loader lets me lift the blade, with snow, as needed, unlike a normal snow plow on a truck. We had 6' + piles in some places, and I was pushing snow over the top when I didn't want to transport it. My dream would be a nice, warm cab, but until I get a new barn, it ain't gonna work. And, the other 9 months of the year, I just don't want a cab. If I was mowing in the summer, sure, but I don't.
Brent 420 Auger Wagon (A50514)
Brent 420 Auger...
2016 CATERPILLAR D5K2 LGP CRAWLER DOZER (A51242)
2016 CATERPILLAR...
2006 Ford Crown Victoria Sedan (A50324)
2006 Ford Crown...
1996 Elgin Pelican Series S Street Sweeper (A50322)
1996 Elgin Pelican...
2016 Ford F550 4x4 Bucket Truck with Altec AT41 - 46FT Rotating Bucket and Jib Winch (A52128)
2016 Ford F550 4x4...
UNUSED FUTURE QUICK ATTACH PLATE GRABBER (A51244)
UNUSED FUTURE...
