snow pusher vs. rear 3pt blower
   / snow pusher vs. rear 3pt blower #31
I used an open station B7500 and a 4' rear snowblower for 5 years. I bought a piece of Plexiglas about 4" wider on either side than the roll bar, and the height of the distance from the top link to the top of the roll bar. I drilled holes in the Plexiglas and attached it with 4 u-bolts. It wasn't a cab, but it made a BIG difference on how much snow the wind blew back on me. Face facts, you won't always be able to blow with the wind, and even in a cab there are times when the blowing snow will stick to the glass and obscure your view.
I did the plexiglass on the ROPS when I had a rear blower. It was an enormous difference in the amount of snow that blew onto me. The only change to it that o wish I had done was leave the plexiglass about a foot wider then the rops on each side and make a 45 degree bend forward, so it kinda curved around me, blocking even more. Plexiglass can easily be bent with a torch or heat gun on the bending point.
   / snow pusher vs. rear 3pt blower #32
I am glad you can testiy to the difference the Plexiglas makes. I agree that bending it as you suggested would like help more. I think most people may underestimate the difference the Plexiglas makes. As there is no heat to warm it, snow sticks to it less than the glass on a heated cab.
Kevin.... any pics of the plexiglass?
   / snow pusher vs. rear 3pt blower #34
Not to derail the thread but how thick of plexiglass are you bending? I am going to build a cab and this will change my design.
   / snow pusher vs. rear 3pt blower #35
There is no need to drive in reverse with a 3pt blower if you get an inverted blower. They're extremely popular in places that get a lot of snow, and most of the good ones are actually made in Canada (where they're very popular). Some folks with small tractors (not your L3901) worry they won't be able to drive through the snow if it's really deep, and some folks think driving over the snow will compact it, but pretty much everybody who uses one says the blower easily lifts and throws the bit that gets driven over.
The only real downside is they cost a bit more than a regular 3pt blower, but it's still way less than a front-mount blower'
My L3200, which is the same tractor has not been able to drive through, much less plow through several snows here in the Denver, CO area in the past 2 winters.
A little over a foot of really wet slushy stuff was causing me problems. 2' of snow stops me from moving, much less plowing. Depending on the snow they get, an inverted blower is VERY INAPPROPRIATE for a 3000 series L tractor. I wouldn't want one if my tractor was double the weight of my current machine. For an inverted blower I'm guessing you need at least an 8,000lbs machine unless you just get a dusting of snow.
Heck when we got a foot & a half a month or so ago with a lot of wind I got some dense 4' drifts. With chains on the front I could barely even push my blower into them. I had to make repeated runs & was making progress at about 3' per minute. Those were super dense drifts from 60+ mile an hour wind though.
   / snow pusher vs. rear 3pt blower #36
No, I disagree, that is not the only downside. The inverted snowblower means you have to run the tractor over or through the snow BEFORE it is removed or blown. No doubt "inverted" blowers are effective in many places under some conditions and they do offer an alternative. But if you wade into very deep snow, especially snow that has settled and packed some before removal, a small tractor dragging a blower behind will simply get hung. Won't work. They probably work well with large tractors with lots of clearance but not with smaller tractors having less clearance.
Also, the only cases where an inverted blower would work well with smaller tractors are cases where the snow is not very deep and to me that is where you did not need a blower in the first place.
Lots of people with smaller tractors in places that get a lot of snow seem to disagree. The key seems to be not waiting until there's two feet of snow to drive through. That's the sort of compromises you have to make with a smaller tractor.
Nobody said it was a perfect solution, but neither is a conventional blower that forces you to drive backwards, or a front blower that removes your front bucket.
   / snow pusher vs. rear 3pt blower #37
Yes, that is exactly what I was talking about in reply #30. The removal tool has to meet the snow first or you will just get hung up using these 20 to 40 hp range tractors. My vacation place is in the mountains where it is fairly common to arrive after a 260 mile trip to get there and find packed snow 1 to 2 feet deep (sometimes more.) Can't get car/truck in & have to wade in to get the tractor & blower. I use the front end loader to clear enough room to maneuver with a 5ft snow blower. Once the snow blower is aimed into the snow -- no problem. That's with a 24hp B2150. I did find AG tread tires helped a bunch. The creeper gear is a big help too.
   / snow pusher vs. rear 3pt blower #38
Like essentially all tractor utilization situations, it depends on the circumstances and the best you can do is match the tools to what you deal with the most. Those with smaller tractors in places that get a lot of snow are not using an inverted blower unless they can watch it snow and pounce on it at the right times. What works best in an environment for some users is unworkable in others.
   / snow pusher vs. rear 3pt blower #39
Sure. My point was that it's an option that works very well for some people. I don't know what the OP's exact situation is, and I doubt anybody else here does either. There is no perfect solution, especially when we're talking about a fairly small tractor, but it seems fair to point out the possible solutions to the OP rather than to make a blanket statement that something is "very inappropriate" when we don't have all the facts.
   / snow pusher vs. rear 3pt blower #40
Here's my situation... I just bought a Kubota L3901. It snows where I live... and I mean snows (150 inches average!) Straight across from my driveway after the shoulder is quite a nice little drop off (Ill explain later). My question: Should I buy a snow pusher or a rear mount blower. Now for the pros and cons (as i see them). Pro for blower. I will never run out of room for putting snow on either side of driveway which is blacktop, my bucket would be freed up for moving banks back, etc.. Cons for blower: It is very windy on the hill I live on (open work station snow blowing everywhere as it is), having to drive in reverse, having to add extra rear remotes at quite a good cost :mad:. Cons for pusher: because it doesn't have a bottom I don't feel like I can pick and move banks back, bucket is off machine, etc. Pros for pusher: Cheaper to buy, rubber scraper easier on driveway, I have that drop off across street to push snow off. What do you all think. Just trying to ask question snow so I can be ready to go by next winter. Ugh...winter.
Chris
Since this has come up....are you in a position where you can get to the snow as it builds, or are you forced to wait until you can get to it, regardless of how deep?
UNSUED AGT MX-MRT14 STAND ON SKID STEER (A51243)
UNSUED AGT...
2022 CATERPILLAR 305CR EXCAVATOR (A51242)
2022 CATERPILLAR...
UNUSED FUTURE MINI EXCAVATOR COUPLER (A51244)
UNUSED FUTURE MINI...
2014 Ford F-550 4x4 Ext. Cab Auto Crane 6406H 6,000LB Crane Service Truck (A50323)
2014 Ford F-550...
2020 Ford F-250 Ext. Cab Pickup Truck (A50323)
2020 Ford F-250...
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50775)
IF YOU BID ON AN...
