snow pusher on 4720
   / snow pusher on 4720 #1
MikeF
Maryland
JD 3039R cab
I am going to build a snow pusher for my 4720, I have the CX loader with skid steer mount. What I am wondering is how wide do you think I can go. I have an old 8' and a 6.5' snow plow moldboard that I plan to convert. Any of you guys have one on yours.
thanks,
Mike
   / snow pusher on 4720 #2
Hi Mike,
I push a 7 1/2foot Fisher with my JD3320 with no issues.
   / snow pusher on 4720 #3
I use a 7 ft Frontier front blade that replaces the bucket. I have not had any problems.
thanks for the input my concern is more once I convert the blade from an angling snow plow to a snowpusher. the amount of snow the pusher can cradle could be an issue I may just cut the 8' moldboard down to 7' just to be safe.
   / snow pusher on 4720 #5
If I had that size tractor then I'd use the 8' plow and rig it to at least take a 15 deg angle (manually if not hyd.). Even straight, it will handle 8' plowing, no problem IMO.
I have the 4300 with a 7' Western blade, and that is handled with ease. Just incredible what can be bucked away straight ahead.
You can always cut it back if for some reason the 8' doesn't work. But can't wish for more (like I do). :)
   / snow pusher on 4720 #8
I have used a 6 old western, manual angle mounted in my bucket. 2 pins and a chain on/off. and the pusher in my avatar was a 66" and worked well. Now I'm going to try a snowblower as to eliminate piles all together' . If you haven't bought a plow yet check this one out.
http://erskineattachments.com/attachments/snow-light-material-blade/
   / snow pusher on 4720 #9
I have a JD 110 TLB, which is similar size to your 4720 but heavier. I have and older HD 10' fisher plow with about 3' sides welded on (to make it a pusher) and a skid steer mount the back. I also have 4" runners on the bottom of both sides. For the winter I have chains on the rear tires and leave the BH on for added weight, also have loaded rear tires. The 10' is a good size for the 110, so I would think the 8' would be fine for your 4720.
   / snow pusher on 4720 #10
I use a 7' Vernig pusher on my Toolcat. I have a JD 4520 but never tried it on the JD. My pusher is 3' tall in the back and sides. The TC pushes it just fine, even with full box of snow. The TC is a bit heavier than the 4520 but it does OK with the pusher unless the ground is icy. I would stick with the 8' plow. Your blade is probably not near 3' tall in the back and sides. You can always use less of the 8' blade if you need.
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2004 TRAVIS 48' WALKING FLOOR REFUSE TRAILER (A54607)
2004 TRAVIS 48'...
PumpJack Brand Pump Jack (A55218)
PumpJack Brand...
2018 KENWORTH T880 DAYCAB (A53843)
2018 KENWORTH T880...
2006 GMC C7500 DUMP TRUCK (A51406)
2006 GMC C7500...
23110 (A53424)
23110 (A53424)
