Snow Snow plowing recommendations for gravel road
   / Snow plowing recommendations for gravel road #11
I have the advantage of having a tilt cylinder with float. My rear mounted blade follows the road contour pretty well.
Jack
   / Snow plowing recommendations for gravel road #12
The board also is a blunt edge rather than a cutting edge, so does not throw gravel with the snow. The result for me is that I am able to plow almost down to the gravel without moving the gravel. I just drilled 2 holes in my blade, and attach the board with 2 bolts. When I want to use the blade for grading in the spring, I just take off the board. I believe I heard about this from someone on this forum, but I can’t remember who.
Wow, this is a great idea. I have been wondering how to shove snow off gravel road without messing up the gravel. I am also planning to set up home in a rural area and trying to figure out what equipment I would need.
   / Snow plowing recommendations for gravel road #13
This summer, I'll most likely replace the adjustable skid shoes with heavy duty swivel wheels like the plow originlally had.
Most all road plows use wheels to set the height and they don't dig into the roadbed like skids do.
   / Snow plowing recommendations for gravel road #14
The cheapest will probably be a plow for your ATV. 2nd cheapest a rear blade for your tractor. Just keep in mind how little you get to use it, so a rear blade for tractor would be multi use.
   / Snow plowing recommendations for gravel road #15
I modified a Myers plow a few years ago to mount on the loader arms. It had a power angle but on my Case DX35 it wanted to push the front end opposite the angle of the blade. I sold it and the buyer had it modified to go on his 100 horse John Deere and it worked much better. I just use the bucket but it would take years to clear a mile. I’m not to far from Monroe City up in Knox County.
   / Snow plowing recommendations for gravel road #17
I’m in the process of building a new home off the beaten path in NE Missouri. I’ll live back on a hilly and currently uneven gravel road about 1 mile off the paved road. I’m looking for the best snow plowing set up for my situation.
I am fortunate to own a SVL90-2 tracked skid loader w/cab, an M7060 w/ cab and a Can Am 850 ATV.
We only get maybe 2-3 “plowable” snows a year, the last of which was about 6”. I recently plowed with a buddys atv with a plow and it did well but took awhile and I’d sure like to take advantage of one of my cabbed vehicles if possible.
Any recommendations on which vehicle and what type of implement (plow, snow pusher, etc)?
Thanks in advance
I have lots of years of gravel road plowing experience. Anything front mounted will remove your gravel along with the snow unless you leave a few inches of snow on the road. For heavy snow I hold my loader bucket about 3 inches off the road surface and have a rear blade attached with the moldboard rotated 180 degrees, so I can skim the road in float. The front bucket pushes the heavy snow and the rear blade removes the few inches left on the road. With the blade facing backwards it will ride on the gravel but not move it. You will probably get a lot of people who suggest a snow blower, but that’s an expensive piece of equipment to buy and maintain for just 2-3 times per year of use. For heavy weekly snow, yes a blower is worth it. My 2 cents.
   / Snow plowing recommendations for gravel road #18
I like that. I have some old CJ mirrors I was planning to mount on my loader
For the Kubota, I made up these brackets from some 3" angle iron. They work on many Kubota FELs. I'm not sure they will fit a Case though.
   / Snow plowing recommendations for gravel road #19
I had a 4' pusher blade for my Craftsman lawn tractor that I adapted and chained to the bucket of my Kubota B6100. Used it to clear my 300' gravel driveway and 1/4 mile gravel community access road. When we got 30" snow, I ditched the blade and just attacked it with the FEL.
   / Snow plowing recommendations for gravel road #20
In my mind you don't get enough snow to warrant a blower.
I do around a mile of private road & drive, all gravel.
The most heard complaint about plowing gravel is getting it into the grass.
I tried plow shoes, they just dug into the dirt as the ground isn't usually frozen the first couple and maybe the last couple times I have to plow.
PVC pipe was suggested, tried, it broke in cold weather.
Steel pipe is really hard to cut lengthwise and harder to attach.
Ended up using angle iron bolted to the cutting edge.
(In pic., bolted in place of cutting edge because holes were already there.)
Easy to attach & take off.
I can even plow paths in the yard with NO damage come spring.
2" x 1/8th" seems to be enough.
Works as well on front or back blades.
I even strap one on my york rake & use that to plow surprisingly well.
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A52576)
2018 FREIGHTLINER...
2025 JOHN DEERE 408R LOT NUMBER 10 (A53084)
2025 JOHN DEERE...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
New Holland LX885 Skidsteer (A51573)
New Holland LX885...
