Snow plow wings
/ Snow plow wings #1
greif
kaukauna,wi
Yanmar sx3100
Has anyone used these rubber wings? How are they?
54 Plow Products
I as thinking of of adding about 8" sheet metal on each side but maybe this is an option
/ Snow plow wings #2
I had something like those on my plow truck, ford f-150, back in Erie PA. Serious snow country. We owned a large commercial building there at the time and had numerous parking lots & drives to clear on a near daily basis during the winter. I loved them, I could scrape snow right up to a curb or building without causing damage to the concrete or my plow. I'm looking for a set for my Kubota BX2763A blade, know where I might find them? I have a lot of large rocks along the one side of our driveway and those would save me a lot of agita.
/ Snow plow wings #3
I made a similar setup using a thick plastic mudflap.
/ Snow plow wings
McMaster-Carr
Mcmaster has heavy conveyor belting, wonder if the .36" thick stuff would work?
/ Snow plow wings #5
The ones I had on my plow truck were a full inch thick. TSC sells 3/4" thick horse stall mats, that's what I might use if I can't find anything else. Needs to be stiff enough to scrape hard snow.
/ Snow plow wings
The conveyor belting has reinforcing in, the .36 thick ones have 2 layers which makes them really stiff. Floor mats are usually pretty floppy so you are right they would need to be thicker
/ Snow plow wings #7
I have some old conveyor belt I use to protect the cement in my garage from my tire chains. It's 2' wide and was replaced because gravel wore the center down past the cords. The ends are a good 3/8" thich. Maybe because what I have is used it's not that stiff. I wouldn't think it would be strong enough for a plow wing. I think I would just find an old tire and cut the tread off and try that. Lots of free tires around.
16ft. T/A Utility Trailer (A64557)
16ft. T/A Utility...
2004 Suzuki GSX-R750 Motorcycle (A64557)
2004 Suzuki...
213137 (A64276)
213137 (A64276)
2024 JCB 35Z-1 EXCAVATOR (A65053)
2024 JCB 35Z-1...
2022 EZ-GO ELITE...
213089 (A64276)
213089 (A64276)
