snow plow top extension
   / snow plow top extension #11
Ed, a 8"-10" piece of rubber belting across the top will do the trick and is an easy drill & bolt job. You can bolt ti on sticking straight forward, if the snow get's deep enough, it will roll the belting upward and deflect it just like it was a vertical blade extension.
   / snow plow top extension #12
Rusty, not sure if I asked before but, how wide is that blade,
looks like a good 8 1/2 footer.
   / snow plow top extension #13
Find a horse barn that is replacing their stall mats, standard size is 6 ft by 4 ft - a 6 or 8 inch wide 1/2 thick inch strip should do it.
Some are 3/4 inches thick, but most barn owners don't want to move those around too much, so try them once and then go to the 1/2 inch ones.
   / snow plow top extension #14
As long as you have traction and power to push, it wont matter how tall the blade is, if you have enough snow it will come over the top.
IT comes over the top of my 28" blade just the same as it comes over the ~40" high blade on one of the loaders. Same as it comes over the ~36" high boxes too.
Just keep in mind that the more snow you hold in the plow, the harder it is to push. IF you have plenty of push power in reserve, go for it.
IMO, those rubber flaps dont do a whole lot on the newer style plows that are curved more at the top. But are nice on older style plows like the meyers
How would round baler belting do? I have some I took off years ago but it is only 6" wide. I could set it so it set out all the way in front of the blade.
   / snow plow top extension #17
It'll help, all you'll be out is some drilling and a little hardware. In VA it's prolly a while inbetween deep snows.
   / snow plow top extension #18
how stiff is that? You want something pretty stiff.
Alot of people use an old tire tread. "think a recap section that blew off a semi"
2006 FONTAINE TH55 SERIES 102" X 42' LOWBOY TRAILE (A51243)
2006 FONTAINE TH55...
2002 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2002 Ford F-150...
Unused 2025 CFG Industrial MY50R Mini Excavator (A50322)
Unused 2025 CFG...
2002 KENWORTH W900 TRI AXLE (A52472)
2002 KENWORTH W900...
UNUSED FUTURE HYD HOSE BUNDLE (A51244)
UNUSED FUTURE HYD...
New Kivel 4200 lb. Skidloader Forks (A50774)
New Kivel 4200 lb...
