Snow Plow started
   / Snow Plow started
Very nice, you may want to consider adding one or two more trip springs, I have a feeling that blade will be tripping often on you.
Skyhook
I have 2 more springs and the mounting hardware ready to go. I would rather add them if needed than break something. This blade is only18" wider than my last one so I figured 2 was a good starting place.
Cam
   / Snow Plow started #32
You will love that blade set up. :thumbsup: I still have my L3400 setup this way. I mostly use the bigger tractor now since I have chains and a cab for it. Are you planning on running tire chains?
   / Snow Plow started
I have tire chains for the R4 rears. The rear aux hydraulic lines do not have much clearance from the right rear tire (1 1/2 inches) and have not rerouted them yet. Another job on my list. I have some old car chains that I can make work on the front. As this is the first snow in 2 years I have not had the need to try.
A canopy is also an the list as well as reworking the skid shoes on the corners to save the grass.
Cam
(2) 48" HANG ON FORKS (A54757)
(2) 48" HANG ON...
DEUTZ MARATHON...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A56436)
Michelin CARGOXBIB...
2019 DODGE RAM 3500 (A58214)
2019 DODGE RAM...
2011 JACK COUNTY 130BBL VAC TRAILER (A55745)
2011 JACK COUNTY...
