Snow Plow retrofit to Quick Attach Loader Mount
   / Snow Plow retrofit to Quick Attach Loader Mount #21
Nice work!
I'm curious why you didn't use a solid quick attach plate. Like the one in the link below.
Solid quick attach plate
I'm making on this fall too.
The cylinders were from Surplus Center and have a 6in stroke from 13.5 to 19.5.
I bought the quick attach plate sight unseen. Given the option, I may have bought a full quick attach. In this case it didn't matter because I used a 1/2" backplate.
Marcus
Update on the plow...
I ended up modifying the finished product to go on the 3-point, so I would still have the bucket available and it works great.
   / Snow Plow retrofit to Quick Attach Loader Mount #24
nice job on the welds,you can see from the color of some of the bushings you had good heat and penetration.the cuts you made using the templates look good also all in all job well done.id like to do the same for my tractor but if winters keep up like this i wont need to:(
2007 Ford F-350 9ft. Stakebody Flatbed Truck (A55852)
2007 Ford F-350...
2019 MACK GRANITE (A58214)
2019 MACK GRANITE...
1983 Ford 8000 Tandem Grain Truck (A59814)
1983 Ford 8000...
Informational Lot - Financing (A56438)
Informational Lot...
bad boy zero turn 72 (A56859)
bad boy zero turn...
2003 PETERBUILT PB330 DUMP TRUCK (A60430)
2003 PETERBUILT...
