Snow Snow plow/pics
/ Snow plow/pics #1
Hvytrkmech
I love this tractor.
/ Snow plow/pics #2
That is one nice setup...you must have sold the truck by now :)
Heads up.... you should reset your mid mount mower deck arm, to the highest position on the nob. They're hanging to low.
Thanks for sharing.
Bird
/ Snow plow/pics #3
Is that a 6.5' plow? At what point does that wide blade hang the tractor up? (4-6" of dry snow, wet snow etc)
/ Snow plow/pics #4
This is my setup from last year, this year the backblade was replaced with a 75' Meteor Blower.
/ Snow plow/pics
It's a 7.5', the tractor has not hung up yet, thurs it plowed 13" of dry snow in high range, then today 8- 10" of snow, sleet mix. Last winter it moved 6-8" of heavy wet snow with no problem, however, I had to put in low range to push the piles back. All in all it works very well.
Tim
/ Snow plow/pics #7
Hey Hvytrkmech:
Happy New Year!!
Nice plow setup!!
How about a couple of pics of how you attach the lower arms into the bucket. Is it a relatively quick connect system? Any major stress to the center chain hook? Thanks
simonmeridew
/ Snow plow/pics
simonmeridew said:
Hey Hvytrkmech:
Happy New Year!!
Nice plow setup!!
simonmeridew
Thanks and happy new year to you too! I used an older frame mount for a chevy p/u, however I modded it to fit the angle section of the bucket on my B7610, it was a little bit of steel and welding + 4, 1/2" bolts to hold it in, that way I can just unbolt the frame hookup for the summer. The plow disconnects from the bucket in about 30 seconds (literally), pull the chain off and slide the two pins, you can see all of in the pictures I already posted, however I will take more detailed pics and repost them so you can see it up close. Just be advised the plow I use is 7.5' off a truck and it is heavy, I have to have the spreader atleast 1/2 full to counter weight it. I welded some angle iron on the top of the bucket, look closely at the pics, it does not stress it at all.
overall it does an excellent job, my neighbor has a M/F with a large blower on it, he can't beleive how this little B7610 push's snow the way it does.
This is the top of my driveway,
/ Snow plow/pics #9
Hvytrkmech,
Looks like you've got the R4's. How do you like them? How's the snow traction and mud traction on your property - looks like you've got some hills.
Ever wish you had gotten the R1's instead?
/ Snow plow/pics
No on the R-1's, I like the R-4's, they do slip in the slick mud, however I stay out of slick stuff anyway, as far as snow goes I have not had a single problem yet, the only exception is ice. The R-4's are much easier on my grass to, I mow with a 54" mid mount and have a lot of hill work, not a single problem there either.
As a side note, I usually have the sander fully loaded, so that adds 7-800#'s to the tractor and makes a large difference in the way it push's snow.
Tim
/ Snow plow/pics #11
Hvytrkmec,
I am looking to build a plow setup like yours. Could you post some pics on the mounting set up in the bucket??
I have a B7610 and a 7' fisher plow but I do not want to extend it too far out in front of the bucket because of the weight.
Did you weld in mounting bolts to the bucket??
Mike
/ Snow plow/pics #12
i will be building the same setup soon. i have looked at all the setups on here and chose to keep the loader on for now and then make a QA next year. i have a DK-35 and was going to use a 7 foot fisher, you have a 7.5 is there a difference in height or just length and weight??. more pics would be nice too. thanks
/ Snow plow/pics
I drilled 4, 1/2" holes in the angled section of the bucket to secure the frame assembly. I will definetly post some more pics for you so you can mock up your set up. I have a 7.5' plow so your 7' should not be a problem at all. There are no hydraulics hooked up on the plow, I put some angle iron on the a-frame to hold the blade straight. I will pull the frame mount out to take more detailed pics, just be patient, more snow coming in sunday so it will be after that.
Tim
/ Snow plow/pics
There is a small difference in weight and width, the length that it sticks out of the bucket will be the same. I chose to keep the bucket also and am glad I did, I can push and stack snow banks 6-8' high with no problems, plus if I need the bucket all I have to do is slide 2 pins and pull the chain, (30 seconds tops).
Tim
/ Snow plow/pics #15
i was thinking the same, as far as going back to the bucket quickly. how did you secure the cylinders from moving?? i thought i saw on TBN somewhere there was a company who made bars with pins to manually angle the plow at different positions?? any idea?? i liked the pics, keep them coming. hopefully we get dumped on tonight!!
2019 Peterbilt 567 Cab and Chassis Truck, VIN # 1NPCX7TXXKD273140 (A65563)
2019 Peterbilt 567...
(4) Heavy-Duty Pipe Gates (A66408)
(4) Heavy-Duty...
2011 AMERICAN 14 T/A DOG HOUSE (A65643)
2011 AMERICAN 14...
Landhonor Mini Skid Steer Rock Grapple (A62679)
Landhonor Mini...
Kewanee 12A Cultimulcher (A66408)
Kewanee 12A...
40' One-Trip Shipping Container (A66285)
40' One-Trip...
