snow plow on LB1914
/ snow plow on LB1914 #1
TimPa
nw, Pa
Kioti LB1914/FEL KL200, Ford 3600, Ford 8N
anyone figure out a way to attach a snow polw system onto an lb1814?
thanks
/ snow plow on LB1914 #2
I had a friend make a custom bracket that came off the frame so that I could mount a plow off a jeep. I used the loader and a chain to raise and lower it. If you want to see pictures I can find some. It worked extremely well. Could push a ton.
Prior to this, my first attempt was just to chain the plow to the bucket and it actually worked surprisingly well. You can see this set up at the link below. If it doesn't work just youtube "LB1914 snow plow"
Low cost tractor plow kioti lb1914 - YouTube
thanks Ron. nice set up you have there.
i though about doing that, but i was worried about applying too much force on the loader system. son has a kubota that just hangs off the front of the frame and is 4 way. kind of nice. funny kioti doesn't have any???
where are you in pa?
