Snow plow frame and grill guard
   / Snow plow frame and grill guard #1
joes_427_vette
Midwest
IH Cub Lo Boy, 955 John Deere , TC 55 DA New Holland, Bolens HT 20 and 1456
Bought a 5' western plow with cylinders and a Kubota mount ( don't know what it fit but it has a kubota tag and serial number ) off the computer for $100. The stock JD models are only 54" wide and do not cover the wheel tracks of my 4110 when angled. I designed an under frame mount with some scrap pieces of iron and it turned out to be very functional. I mounted some work lites on the roll bar, now constructing a weight box for the rear to off set the plow weight.
   / Snow plow frame and grill guard #2
Mornin Joe,
Hey that looks real good !!! Nice sturdy mount and that power angle looks great. :)
How much weight you gonna put on the back of the tractor ?
Hi Scott; I have some 2x2x 1/4" angle in the scrap pile. I welded two sections together approximately 13 x 25 in a rectangle. The plan is to flip the top one upside down and have slides on the side so I can add or subtract weight and keep it boxed in. Also use it on the TC 55 DA New Holland as a front weight. I have some bar stock that was cut in 2 foot pieces. For the 4110 I figured on starting at 500#. I have chains but if the weight box works out I may be able to get by without them.
2024 ArmorLite Aluminum End Dump Trailer (A56435)
2024 ArmorLite...
2016 PETERBILT 579 (A58214)
2016 PETERBILT 579...
2017 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2017 Ford F-150...
PALLET TOTE OF BOAT MOTOR PARTS (A58374)
PALLET TOTE OF...
large capacity skid steer bucket (A56857)
large capacity...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
