SNOW PLOW FOR MY 3PT
   / SNOW PLOW FOR MY 3PT #11
BTW I didn't built the adaptor frame tough enough. (2x2x1/4 angle). Made it through last winter. Still works. Built a new HD 2" box tube frame that I can use as pallet mover, trailer mover, and plow mount.
is that link that you put at the base of the 3pt swivel? looks very simple maybe I'm over thinking this. If I went with the 4Inch square pipe stait out the back of the plow I could conect directly into the hitch pin at the angle shown. the plow would be tilted a few degrees forward but the force of plowing would go directly to the frame. I could be wrong though:confused:
here is a picture with the thought of the 4"
   / SNOW PLOW FOR MY 3PT #14
Here are a few more pics.
No swivles, but those built into the 3ph arms. There is enough play in the whole system to allow the blade to stay flat. I can adjust the cutting blade angle some by adjusting the 3ph height.
The black arms off the blade are the original mounting arms cut down. The arms pin to the angle iron 3ph frame (unpainted steel). The chain picks up the blade when the 3ph is raised.
I like the idea of connecting the frame has some promise. Would like connect to my tractor's frame, but don't have the time.
Last winter I pushed till a lost traction many times. No damage, but I did break the pins connecting the plow mount to my adaptor twice. Thats ok because I had designed them to be the weak point. A shear pin of sorts.
Hope this helps some.
Thanks Bw Wis
I have had a freind over that slapped me up side the head for trying to rethink the wheel on this one.I have gone with his idea of two peices of heavy angle off of the frame in behind the ram. coming up about 12 inches two hold the top link and use the existing holes in the back mounts for the 3pt pins. this would be a standard 3pt hook up and easy on and off of the tractor . this way if a snow blower comes into the picture in the future the switch over would be simple.
   / SNOW PLOW FOR MY 3PT #16
Glad you have good plan. Sounds like its work great. Post some pics when its done.
   / SNOW PLOW FOR MY 3PT #17
I'm wondering why anyone would want to convert a front mounted blade to a 3pt
Much easier to plow forward and see where you are going Plus not sure but I would think a lot less wear and tear on tractor and on your body plowing forward. Just my 2 cents
   / SNOW PLOW FOR MY 3PT #18
5' plow ahhhh how cute! must have been for a garden tractor er bx series
my 6' rear blade is barely wide enough to cover my rear when angled.
id add a foot to each side.
First, that plow pre-dates the BX and the 5'push plow would like have been on a B, at least. That thing would be a real handful on a garden tractor.
As a push plow, a 60" plow can be quite adequate. I agree that angled for a rear applications would make it rather closer to a 4' clearing path.
Perhaps the OP has a narrow tractor, as he stated, and this isn't a worry for him?
just thought i would finnish this old thread with some pics of the finished product
Fork and Frame Skid Steer Attachment (A56857)
Fork and Frame...
2016 FORD F-550 UTILITY / MECHANICS TRUCK (A58018)
2016 FORD F-550...
2025 SDLANCH SDLE20 MINI EXCAVATOR (A58214)
2025 SDLANCH...
CASE INTERNATIONAL 3950 - 21' DISC HARROW (A52708)
CASE INTERNATIONAL...
Caterpillar D6K LGP (A53317)
Caterpillar D6K...
HARRINGTON CHAIN HOIST (A52708)
HARRINGTON CHAIN...
