snow plow angle cylinder
/ snow plow angle cylinder #1
doublek
Roaring Brook PA
Kubota L 3430 with cab
trying to find out brand name of a 4 ft dirt plow- was on b7100 kubota-I need a replacement angle hydraulic cylinder- mine is scoured and leaking-plow is not made kubota I bought it used-maybe 20?yr old?
no name- no serial number - M-233 is white paint stenceled on cutting edge holder- heavy duty well made unit
any info greatly appreciated!
doublek
/ snow plow angle cylinder #2
Picture?
Can't you just measure the cylinder? I'm sure it's a standard size and nothing proprietary.
/ snow plow angle cylinder #4
Yep, just measure it. Probably not a big cylinder and likely $50-$100 or so to replace
update- took cylinder to a hydraulic repair shop - told me it not really a cylinder but a hydraulic ram -only has one fiting --when it was asembeled -the piston has a flange on the fluid end then it's inserted in the tube and a collar is welded to the tube. to repair it you would have to use a lathe turn down the weld replace scoured parts piston and tube?-then reweld collar to tube then replace packing and end collar and retaining ring-- cleaned plow and found faint kubota trade mark- they told me they didn't make a front plow for a B7100 it must be for another tractor- will take pics send to kubota in ca. and post here with dimensions I couldnot find replacement it's short stocky with ears on both ends for clevis pins
thanks for your help
double k
/ snow plow angle cylinder #6
Pictures are worth 1000 words
the ram cyl. I need has a 2 1/4 in.piston dia.
2 3/4 in o.d. tube dia
3 1/4 in o.d. collar dia
20 1/2 in extended
about14in colapsed (can't tell exactly because it binds on scour)
the opening between the clevis ears is 3/4in both ends
the clevis pin is 3/4 dia
1 1/2 in clevis center pin distance to tube end
2 1/2 in clevis center pin distance to piston end
only one hyd connection
Michelin Mach X BIB 710/70R42 Tires (A65640)
Michelin Mach X...
Athey 7-12D Force Feed Loader (A62679)
Athey 7-12D Force...
KMC 6700 Rip Strip (A64126)
KMC 6700 Rip Strip...
2003 Ford F-550 Pickup Truck (A66408)
2003 Ford F-550...
2016 Ford Explorer AWD SUV (A61569)
2016 Ford Explorer...
2026 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2026 SDLANCH...
