snow plow angle cylinder
/ snow plow angle cylinder #1
doublek
Roaring Brook PA
Kubota L 3430 with cab
trying to find out brand name of a 4 ft dirt plow- was on b7100 kubota-I need a replacement angle hydraulic cylinder- mine is scoured and leaking-plow is not made kubota I bought it used-maybe 20?yr old?
no name- no serial number - M-233 is white paint stenceled on cutting edge holder- heavy duty well made unit
any info greatly appreciated!
doublek
/ snow plow angle cylinder #2
Picture?
Can't you just measure the cylinder? I'm sure it's a standard size and nothing proprietary.
/ snow plow angle cylinder #4
Yep, just measure it. Probably not a big cylinder and likely $50-$100 or so to replace
update- took cylinder to a hydraulic repair shop - told me it not really a cylinder but a hydraulic ram -only has one fiting --when it was asembeled -the piston has a flange on the fluid end then it's inserted in the tube and a collar is welded to the tube. to repair it you would have to use a lathe turn down the weld replace scoured parts piston and tube?-then reweld collar to tube then replace packing and end collar and retaining ring-- cleaned plow and found faint kubota trade mark- they told me they didn't make a front plow for a B7100 it must be for another tractor- will take pics send to kubota in ca. and post here with dimensions I couldnot find replacement it's short stocky with ears on both ends for clevis pins
thanks for your help
double k
/ snow plow angle cylinder #6
Pictures are worth 1000 words
the ram cyl. I need has a 2 1/4 in.piston dia.
2 3/4 in o.d. tube dia
3 1/4 in o.d. collar dia
20 1/2 in extended
about14in colapsed (can't tell exactly because it binds on scour)
the opening between the clevis ears is 3/4in both ends
the clevis pin is 3/4 dia
1 1/2 in clevis center pin distance to tube end
2 1/2 in clevis center pin distance to piston end
only one hyd connection
WORKBENCH WITH VICE (A68842)
WORKBENCH WITH...
UNKOWN NATURAL GAS GENERATIR (A67714)
UNKOWN NATURAL GAS...
2013 VOLVO A40F OFF ROAD DUMP TRUCK (A65056)
2013 VOLVO A40F...
2012 FOREST RIVER SALEM (A67714)
2012 FOREST RIVER...
2016 Peterbilt 348 26ft. Rollback Truck (A66736)
2016 Peterbilt 348...
2010 MACK TITAN (A67714)
2010 MACK TITAN...
