Snow plow and mount for Kubota B7510
   / Snow plow and mount for Kubota B7510 #21
Although the MMM mounts might be strong enough, I would avoid relying on them. If they won't handle the stress you have then destroyed your ability to mount the MMM. I guess that also would be determined by your intent with the plow. I want to build something strong enough to push dirt/brush, etc. so will not use those mounts.
Thanks again for the pics and info.
   / Snow plow and mount for Kubota B7510 #22
hey ASGAR, Could you post up some dimensions? Or better yet an itemized materials list? :D I'm gonna see if I can get my steel tomorrow, I sent you an email but I didn't want to rush you. I think that I can eyeball most of the pieces though.
I'm thinking:
2 --1.75"x6" ---8" tall C channels for the front subframe mounts
2 -- 2"X4"x.25" ---4' long tube for the main rails
1 -- 2"x4"x.25" ---22" long cross piece for rear of subframe
2 -- 1.75"x6" ---8" long C channel "wings" for plow mounts
1 -- 2"(i.d.)x.25" ---6" long Square tube for receiver
1 -- 2"x.375" ---6" long flat stock for receiver back cap/brace
2-- 2"x.25" ---8" long Caps/mounting tabs for rear mounts
2 -- 2"x.5" ---6" long Flat stock for outside snow plow mounts
2 -- 2"x.5" ---2" long Flat stock for inside snow plow mounts
1 -- 2"x4"x.25" ---4" long Brace between front of frame rails
1 --8"x10"x.125" --- Plate to tie front of mount together
2 -- 2"x.25"? ---10" Flat stock for bracing for plow mounts
Anybody see anything in that list that looks off? I tried to describe it as best I could. That pretty much sums up the steel except the hardware needed to mount the sub-frame. I didn't get to the hydraulic mount yet either.
This is my first post btw!:)
Ok, RedNeckRacin....
Earlier it was noticed that I had this frame in my house to take the pics... understanding wife and all... well tonight is her b'day but, for you, I headed out to the barn at 11pm......
Good estimates from the pics...
The actual measurements are:
2 --1.75"x4" ---7-1/4" tall C channels for the front subframe mounts
2 -- 2"X4"x1/8" ---34" long tube for the main rails
1 -- 2"x4"x1/8" ---13-1/2" long cross piece for rear of subframe
2 -- 1.75"x4" ---6" long C channel "wings" for plow mounts
1 -- 2"(i.d.)x.25" ---5-1/4" long Square tube for receiver
1 -- 2"x.375" ---5-1/2" long flat stock for receiver back cap/brace
2-- 2"x.1/2" ---9" long Caps/mounting tabs for rear mounts
1 -- 2"x4"x1/8" ---3-1/2" long Brace between front of frame rails
1 --5-1/2"x10"x3/16" --- Plate to tie front of mount together
2 -- 2"x3/8"? ---8" Flat stock for bracing for plow mounts
For the lift:
Tube hieght is 25", lift arm 18"
cylinder is a 2" dia x 8" stroke
Look at the pics.. now that I have used it a few times I found I do rub the front tires with the wheel cranked over so I am going to cut off the ends, see pic with black tape, the edge of the tape will be the cut line, you can see the rubs in the pic. Then I am going to weld on hangers from the front of the frame, see cardboard mock up. I also took a pic from the side to show that what I was trying to do was to get the plow frame pivot pins as close to the front of the tractor as possible. The 1/8" tubing is already overkill.
...And a few more pics....
Hope this helps.
Good luck, have fun building....
   / Snow plow and mount for Kubota B7510 #26
ASGAR FTW!!! :D
   / Snow plow and mount for Kubota B7510 #27
Well I got it done. Only took me about 12 hours:eek: Asgar you should have told me this was an easy one lol I got a free snowplow while I was at it. I think its a little bit big from the pics but it cleaned the driveway in two passes! :D
Only problem I had was getting the front posts even. That should be taken care of tomorrow. I'm gonna look into getting a cleaner/easier to fix plow though.
Thanks for your help!
If anybody cares, I can post bigger pics up :) I took a video as well :)
   / Snow plow and mount for Kubota B7510 #28
   / Snow plow and mount for Kubota B7510 #29
Here is my BX1850 front hitch hookup. It uses the 3PH to raise and lower blade and is a manual angle.
   / Snow plow and mount for Kubota B7510 #30
Can you show a pic of the rear, how the 3pt moves that rod. I'm getting an idea from seeing your set-up.
JB.
2004 Cat 730 Articulating Off-road Dump Truck (A59213)
2004 Cat 730...
(2) LP GAS TANKS (A58374)
(2) LP GAS TANKS...
2019 PETERBILT 579 DAYCAB (A58214)
2019 PETERBILT 579...
2014 Ford Taurus Sedan (A56859)
2014 Ford Taurus...
1324 (A58374)
1324 (A58374)
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
