Snow, Freezing Rain, Rain and then Snow. When to clear up?
   / Snow, Freezing Rain, Rain and then Snow. When to clear up? #1
Avondale
Platinum Member
Apple Hill, Ont
Kioti DK35 and Kioti NX6010
We are having a bit of winter here, started with enough snow to warrant clearing but freezing rain is now falling with rain imminent. More snow is expected to follow, (later?). Today, I have elected to wait for the rain to stop, clean up what is left. Clearing before the rain would leave hard pack for the water to freeze on, making a skating rink of my driveway. When do you clear up?
   / Snow, Freezing Rain, Rain and then Snow. When to clear up? #2
For me it depends on the long term forecast.. This storm it's going to be very cold for several days after so I cleaned up while it was still fluffy.. Down to the dirt.. Right now there is a bit of a glaze i'm hoping for a bit of rain before it ends but I'm not holding my breath.. The temp went from 33 while plowing to 30 now..
Most times your da**ed if you do and da**ed if you don't.. :confused:
   / Snow, Freezing Rain, Rain and then Snow. When to clear up? #3
I'm headed out in a few minutes,32degrees and raining.Suppose to go way below zero tomorrow so it will be like concrete.Only have a couple inches on the ground.I know if I plow is going to be a skating rink tomorrow.
   / Snow, Freezing Rain, Rain and then Snow. When to clear up? #4
If there is Snow on the driveway with freezing Rain,wait till Rain stops before plowing,that will help from turning to ice rink.
   / Snow, Freezing Rain, Rain and then Snow. When to clear up? #5
My feelings exactly. Sometimes it's tough to leave a mess and risk it turning to concrete but I have found that letting the snow absorb the rain and blowing after the freeze is the way to go. Otherwise I have a big sanding job ahead of me...
   / Snow, Freezing Rain, Rain and then Snow. When to clear up? #6
3" and 32F. No rain as yet.
   / Snow, Freezing Rain, Rain and then Snow. When to clear up? #7
I just got finished blowing 7" of the stuff off 4 driveways and a parking area. I will probably have to do it all again tomorrow AFTER I get new lift pins for the blower.
I have a heavy equipment dealer about 6 miles from me. He is not a Kioti dealer, but for the parts I need it doesn't matter. I get most of my parts from him along with some implements.
   / Snow, Freezing Rain, Rain and then Snow. When to clear up? #8
We only had an inch or so of snow late yesterday afternoon. Then it turned to freezing rain most of the evening. Today it's 50* F and everything is melting and turning the ground to mud.
It's a tough call when to go out and clean up. If freezing rain is in the forecast I wait till after the rain to plow. If you plow before freezing rain you are right that you'll have an ice skating rink on the hard pack base.
   / Snow, Freezing Rain, Rain and then Snow. When to clear up? #9
Absolutely, well said.
Once when I did snow contracts a client showed up a day early and bitched that his drive had 3" of snow.
I explained that the forecast had freezing rain coming up and that I did not want to leave him with a skating rink.
The irate AH insisted that I plow, so I did the best job short of sweeping with a broom.
He needed to call a tow truck next day and I stood by without a comment. (think he got the message)
   / Snow, Freezing Rain, Rain and then Snow. When to clear up? #10
Agreed. The snow will also plow easier with the rain crust on top. Wait until it's all done and then head out.
1995 Pro Sports 22ft Center Console Fishing Boat with 25ft T/A Boat Trailer (A48082)
1995 Pro Sports...
2006 Gorman Rupp 14C2 10 Series Self-Priming Centrifugal Towable Water Pump (A49346)
2006 Gorman Rupp...
2008 Ford F-250 Ext. Cab Pickup Truck (A49461)
2008 Ford F-250...
Anvil (A50860)
Anvil (A50860)
2009 Freightliner Columbia 120  10-Speed, Mercedes MBE4000, 6x4 (A50397)
2009 Freightliner...
2014 Chevrolet Silverado 2500HD Knapheide Service Truck (A48081)
2014 Chevrolet...
