Snow, Freezing Rain, Rain and then Snow. When to clear up?
   / Snow, Freezing Rain, Rain and then Snow. When to clear up? #1
Avondale
Platinum Member
Apple Hill, Ont
Kioti DK35 and Kioti NX6010
We are having a bit of winter here, started with enough snow to warrant clearing but freezing rain is now falling with rain imminent. More snow is expected to follow, (later?). Today, I have elected to wait for the rain to stop, clean up what is left. Clearing before the rain would leave hard pack for the water to freeze on, making a skating rink of my driveway. When do you clear up?
   / Snow, Freezing Rain, Rain and then Snow. When to clear up? #2
For me it depends on the long term forecast.. This storm it's going to be very cold for several days after so I cleaned up while it was still fluffy.. Down to the dirt.. Right now there is a bit of a glaze i'm hoping for a bit of rain before it ends but I'm not holding my breath.. The temp went from 33 while plowing to 30 now..
Most times your da**ed if you do and da**ed if you don't.. :confused:
   / Snow, Freezing Rain, Rain and then Snow. When to clear up? #3
I'm headed out in a few minutes,32degrees and raining.Suppose to go way below zero tomorrow so it will be like concrete.Only have a couple inches on the ground.I know if I plow is going to be a skating rink tomorrow.
   / Snow, Freezing Rain, Rain and then Snow. When to clear up? #4
If there is Snow on the driveway with freezing Rain,wait till Rain stops before plowing,that will help from turning to ice rink.
   / Snow, Freezing Rain, Rain and then Snow. When to clear up? #5
My feelings exactly. Sometimes it's tough to leave a mess and risk it turning to concrete but I have found that letting the snow absorb the rain and blowing after the freeze is the way to go. Otherwise I have a big sanding job ahead of me...
   / Snow, Freezing Rain, Rain and then Snow. When to clear up? #6
3" and 32F. No rain as yet.
   / Snow, Freezing Rain, Rain and then Snow. When to clear up? #7
I just got finished blowing 7" of the stuff off 4 driveways and a parking area. I will probably have to do it all again tomorrow AFTER I get new lift pins for the blower.
I have a heavy equipment dealer about 6 miles from me. He is not a Kioti dealer, but for the parts I need it doesn't matter. I get most of my parts from him along with some implements.
   / Snow, Freezing Rain, Rain and then Snow. When to clear up? #8
We only had an inch or so of snow late yesterday afternoon. Then it turned to freezing rain most of the evening. Today it's 50* F and everything is melting and turning the ground to mud.
It's a tough call when to go out and clean up. If freezing rain is in the forecast I wait till after the rain to plow. If you plow before freezing rain you are right that you'll have an ice skating rink on the hard pack base.
   / Snow, Freezing Rain, Rain and then Snow. When to clear up? #9
Absolutely, well said.
Once when I did snow contracts a client showed up a day early and bitched that his drive had 3" of snow.
I explained that the forecast had freezing rain coming up and that I did not want to leave him with a skating rink.
The irate AH insisted that I plow, so I did the best job short of sweeping with a broom.
He needed to call a tow truck next day and I stood by without a comment. (think he got the message)
   / Snow, Freezing Rain, Rain and then Snow. When to clear up? #10
Agreed. The snow will also plow easier with the rain crust on top. Wait until it's all done and then head out.
8ft. S/A Utility Trailer (A48082)
8ft. S/A Utility...
2022 AVANT 860i WHEEL LOADER (A50458)
2022 AVANT 860i...
2001 Sterling L7500 Heil 12Yd T/A Dump Truck (A48081)
2001 Sterling...
2020 KUBOTA SVL95-2S SKID STEER (A50458)
2020 KUBOTA...
2019 JOHN DEERE 325G SKID STEER (A50458)
2019 JOHN DEERE...
https://www.globenewswire.com/news-release/2025/05/08/3077245/0/en/Nerve-Calm-Complaints-Investigated-2025-User-Reviews-Tested-Verified.html
https://www.globene...
