snow depth limit for my tractor
   / snow depth limit for my tractor
Geez, your cabin is very similar to mine. Mine is 14 x 24 with a 45 roof. My roof is metal and it doesn't shed the snow at all. I thought the snow would slide right off.
Do you find the cab a pain in the woods?
   / snow depth limit for my tractor #32
I have a cab on my DK45, too, and wouldn't say its a pain in the woods, exactly. However, it is a bit nerve-wracking to have the cab scraped and whacked by branches. On the plus side, those branches weren't scraping and whacking me! Last summer I managed to bend the bracket for the slow-moving vehicle triangle down over the fender (nearly 90 degrees) and snap off the radio antenna on the cab...otherwise, it survived a summer in the woods pretty well.
At least with the cab model I'm never tempted to fold down the ROPS in tight quarters.
BOB
   / snow depth limit for my tractor #33
Wade,
rd and I are neck and neck... I broke of the antenna last year. I drill out the little metal piece and expoxied a 12" piece of coated copper wire in place. It bends and flexes and works great. I am constantly adjusting the side mirrors and a few scratches have been added.
I plan my routes or cut one when I am in the woods.
Cabin is 12'x18' with loft plus a 8'x18' deck/sun room. I think the roof is a bit more than 45ー
It is partially insulated and we need to finish the insulation in the spring plus put up wall board and paint etc.
http://www.tractorbynet.com/forums/rural-living/157009-6-weekends.html
lloyd
I have a sleeping loft in mine as well. I have my deck on the short side with the roof overhanging to give shade. I built it myself over the summer of 09. It was a great experience and I really love my place up there.
   / snow depth limit for my tractor #35
I take the mirrors off for the summer; they just get whacked everytime I wander into the woods or mow the pastures (where there are spruce trees).
I also pretzeled the FEL level indicator rod last summer; the woods definitely present more hazards than the fields do.
BOB
Where i work most of the trees are small and just bend and catch on everything including my face..friggin cherry trees are the worst. If I have a real problem I just qiuckly chop it down and add it to the pile.
How did you bend the indicator? I put a bunch of logs on the loader once that bent the indicator but just elastically.
   / snow depth limit for my tractor #37
I had the bucket curled so the indicator was projecting above the tube and a small dead spruce slid down along the FEL arm as I backed up. It happened pretty fast and bad words were said. I couldn't uncurl the bucket without doing some more damage, so had to head back to the house for a straightening job.
The SMV bracket was also bent while backing up when a front tire pushed down a sapling that caught the bracket and levered it down over the fender.
I'm not sure when I lost the antenna, but it was rotated down alongside the cab at the time, so I'm sure I just scraped it off with a small tree (or branch). Some of my trails obviously need a bit more width to them...of course, a lot of this damage comes while I'm working on making wider trails!
BOB
   / snow depth limit for my tractor #38
I agree with Westbrooklawn on the technique, and maybe now is a good time to widen the trail out so next time it snows you are more easily able to work.
Nice pics!
That's one of the things I really like about my tractor, the narrow tread. I can fit between or go around most of the big trees.
I've caught that indicator on branches and stuff but always saw it before anything happened. I'm not sure if I would miss it much as I rarely look at it when operating.
   / snow depth limit for my tractor #40
Wade,
Nice shots of the cabin build. I like the incorporation of the vertical logs. I am hoping this summer will be the time to finish everything and clean up and landscape the area a bit...
trim some trees/bushes and expose some of the old foundation and fence lines.
Also I hope to drop a line in the river and launch the canoe... for some reason never did get a chance last year!!!!
lloyd
UNUSED FUTURE XLA59 - 59" DRUM SPIKE LAWN AERATOR (A52706)
UNUSED FUTURE...
2007 IC Corporation PB105 School Bus (A54814)
2007 IC...
LayMor Sweepmaster 300 8HC (A55314)
LayMor Sweepmaster...
2020 Freightliner Bucket Truck (A55973)
2020 Freightliner...
2011 Ford Edge AWD SUV (A56859)
2011 Ford Edge AWD...
2015 MACK CXU CONVERTED TANDEM AXLE DUMP TRUCK (A58017)
2015 MACK CXU...
