Snow Blade
   / Snow Blade #1
farm23
Western, NC
PT-1430, Wright Z-turn mower, BCS 853
I am considering a snow blade for my 1430 and wonder if there are any options I should consider? What is the experience of those who have the snow blade, get a wheel kit or anything else. I will use the blade on gravel roads almost exclusively. Thanks.
   / Snow Blade #3
Back in 2001 the wheels were standard. I love them! We have asphalt on the main drive and crushed limestone on three side parking spaces, plus I plow the grass about 50 yards to the back of our place so I can get to our wood piles and take the ashes to the garden. The wheels keep the blade off the rocks and grass very well if I just curl the blade back a bit, and the edge scrapes the asphalt if I dump the blade forward just a bit.
Do they offer a cutting edge? The 425's blade wasn't offered with one 18 years ago, and I have bent the blade just an inch or so on the corners.
   / Snow Blade #4
the snow plow is what allows me to survive the winters here......mine did have the cutting bar attachment as an option and I'm glad I got it......I cut strips of horse matting and sandwich it between the plow and bar letting the matting stick down about 1 1/2".......I then lower the plow so the matting is just barely touching the gravel surface and plow away......any stones/rocks sticking up will hit the matting which bends back so I'm not regrading the drive each time I plow......I've found that after I've angled, lowered and curled the plow right based on the matting edge that I don't need to adjust it again unless I change direction of plowing....takes just a couple iof seconds to eyeball it correctly.....I tried shoes and they were a complete waste of time and money......I don't have the wheels......my drive is 1/4 mile long gravel with one good steep section......all the delivery trucks know that they can get up my drive in the winter as they say its one of the best done in the area......so I must be doing something right.....lol......when I first moved here I got some quotes to plow my drive and they started at $400 per pass.......well over the course of a winter that would be about $3500 and over the 13 years I've had the pt thats over $40k so that plow blade was a good investment....lol.......Jack
   / Snow Blade #5
btw....the cutting bar does not prevent the plow blade from getting bent.......as I found out when I hit a tree.....:eek: ........Jack
   / Snow Blade #6
Well, that's good to know. :laughing:
Mine without the cutting edge is pretty curly on the bottom corners.
   / Snow Blade
The wheels and cutting bar are options now. Power-Trac's web site does not show how either mount. Are the wheels behind the blade and does the cutting bar clamp on?
   / Snow Blade #8
my cutting edge bolts on with 7 bolts......I imagine the wheel kit bolts on too as that would explain the pair of holes at each end of the plow blade......Jack
   / Snow Blade #9
I can't comment on the current wheels as my 2001 model 425 snow blade has the caster wheel mounts welded onto the frame from the factory.
   / Snow Blade #10
I haven't bent my blade, but can tell you that hitting a semi buried pipe at 20 ish mph going down hill will reorient your position in the Power Trac, and quite possibly is what cracked the metal around the steering ram mount, on the bottom of the tub. Fortunately I had been out in the weather long enough so that my knees were somewhat numb when the seat tipped up and forward, and ran into the metal dash. It was a few hours afterward, in the house that i started to hobble around.
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
2011 Crown Victoria Sedan (A51694)
2011 Crown...
2019 Ford F-450 Utility Truck, VIN # 1FT8W4DT8KEF27612 (A51572)
2019 Ford F-450...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2003 Lincoln LS (A50324)
2003 Lincoln LS...
Charlotte County (A50323)
Charlotte County...
