Snapper Comet Clutch
/ Snapper Comet Clutch #1
RSKY
Elite Member
Kentucky, West of the Lakes, South of Possum Trot.
Kioti CK20S
I need to lower the drive plate on a Snapper Comet lawnmower. This is the plate attacher to the motor shaft that the rubber edged drive 'clutch' acts against. It is rusted on and I am afraid too much force will damage it.
Any suggestions?
/ Snapper Comet Clutch #2
Usually, the rubber drive disk needs replacing. I'm not sure how to get it apart other than it is a keyed shaft usually. Some have a retaining screw.
/ Snapper Comet Clutch #3
the one I had needed to be machined (it had ripples worn in it). It is held on a keyed shaft with two set screws (both in the same hole). Remove the first and then look for a second one.
/ Snapper Comet Clutch #4
The rubber drive disc is held on with 3 some 4 bolts my snapper comet is 3, it takes a 7/16 0r 1/2 inch wrench it's not to hard I have replaced several. The cantelever metal disc it engages against is held on with 2 Allen head screws and has a shear pin it slides onto. You will have to remove the rubber drive disc if you have to replace it either way. I have worked on snapers older ones for 35 years. I will be glad to hel you in anyway I can.JAMESMATTDILLON
2023 SANY SY225C9C5KL EXCAVATOR (A63276)
2023 SANY...
KMC 7406 (A64126)
KMC 7406 (A64126)
New/Unused CFG Industrial MH12RX Mini Excavator (A65579)
New/Unused CFG...
Cattle Feeder (A65640)
2022 Seppi MINIFORST CL 175 Skid Steer Forestry Mulcher (A65640)
2022 Seppi...
