Snake deterrent... will this work?
/ Snake deterrent... will this work? #1
Jstpssng
Epic Contributor
Maine
Kubota L3301
My mother's water supply is a large concrete vault (12x16', +-) over a good spring which comes through the ledge in several places. The water level is stable at about 8 feet which is where the 3/4" overflow is at. It's covered by a 2x4 frame with metal roofing topping that. She has an ultraviolet purifier so her water is clean. However, every summer multiple snakes end up in the well where they drown. Last year one of them tried to escape through the overflow and got trapped; by the time I realized it the water was almost to the top. It would take quite a bit to seal it, and she won't be there for many more years.
I am thinking about putting down some weed barrier, then putting 3/4+ crushed stone on top to discourage them. Has anybody had experience with this, to know if it will or won't work? Luckily we don't have poisonous snakes up here, so with the water purifier they are more of an annoyance than anything.
Thank you.
/ Snake deterrent... will this work? #2
So, where do you think the snakes are getting in?
Are there gaps between the roof and concrete?
If snakes can get in, so can mice and insects. I would want to fix the cracks/holes just from the bacterial perspective.
Around here spring boxes have a redwood 2" sill bolted to the concrete, with enough mortar below to make a tight seal. (Recessed holes for the nut and washer) If you have cedar, cypress or another rot resistant wood that would be great, too, just don't use pressure treated wood. The roof is then fastened to the sill in a removable way, often by an inner ring of 2xs for friction fit to the sill, and fastened to the roof. Don't forget a 1/8-3/16" screening on the overflow...
All the best,
Peter
Yes. I haven't seeen evidence of mice getting in, possibly because we keep it mowed down. Replacing the top would be a chore, starting with adding another layer of concrete to the top to smooth it out. The filtering system takes care of the bacteria et.al., I just would like to keep the snakes out for aesthetic reasons.
/ Snake deterrent... will this work? #4
Would fine mesh screening work?
/ Snake deterrent... will this work? #5
How small are the snakes? I like the fine galvanized wire mesh idea provided you dont get rust/seepage from it into the water.
/ Snake deterrent... will this work? #6
Could it be no mice because there are snakes? :unsure:
Have you considered a wildlife ladder so they can climb out of the water? And a one-way flap in the cover so they can get out but not back in.
/ Snake deterrent... will this work? #7
Thank you.
Believe it or not I put mothballs around areas I do not want snakes getting into. Like my wood piles and sheds. I would put them around the inside and outside of your water shed (not in the water). If you have mice I would put traps out to get rid of them
/ Snake deterrent... will this work? #8
Lighting the wellhouse should discourage most of them. Pulsating ,rotating and other light movement helps.
/ Snake deterrent... will this work? #9
How about spray foam insulation? "Hole-stuff" Cheap, quick, and would fill any holes or openings. I would still screen the overflow.
I'm jealous. That sounds like a wonderful spring.
All the best,
Peter
/ Snake deterrent... will this work? #10
That spring sounds like a really good thing. Even though UV sterilization works very well for microbes and many parasites when done properly there are toxins released by bacteria feeding on rotting flesh that may not be rendered harmless by UV. So even though the esthetic reason for keeping snakes from drowning in the cistern (yukk!) are fine there are other reasons why keeping critters out of the water are a good idea. Can you not stretch 1/4 mesh galvanized screen over the top of the cistern? I wish we had a picture.
Eric
/ Snake deterrent... will this work? #11
My house water supply is an entrapped spring. Four foot diameter concrete rings down to the bottom at around twenty feet. The spring boils up thru gravel at the bottom.
I get frogs in my spring. It use to bother me and I would go down, every so often, and dip them out.
This action got very old. Now the frogs are just left there and considered as added protein.
My "country water" goes very well with JD.
/ Snake deterrent... will this work? #13
I smile at these solutions, which are needed, but cost a lot.
Being retired Navy, I simply screwed some plastic 'gutter-guard' mesh to the inside side(s) of my horse water troughs to provide a "scramble net" for any critter that happened to fall in.
It's been ten years since doing this and I've yet to have to retrieve any drowned carcass after the first 'body'.
/ Snake deterrent... will this work? #14
Jstpssng - Ha, ha - never thought about it that way. NO - you are correct, I DO own a Kubota. The only JD I own comes in a bottle.
/ Snake deterrent... will this work? #15
(y)(y)We wrapped the hardware cloth (mesh) around a 2x4 to make a sort of floating off ramp, with the top of the 2x4 attached to a bit of wire at the edge of the trough so that it can float up and down. We haven't had a body since it was installed either.
I once saw a design for a watering "groove", that was basically a concrete footing with a shallow four inch wide groove in it, fed by a protected float valve at one end. It was said to be self cleaning, wildlife friendly, and easier on animals to drink from.
Perhaps it is a personal foible, but I guess that I am on the page that I expect wildlife to get into water troughs, but that nothing should get into water supplies.
All the best,
Peter
/ Snake deterrent... will this work? #16
".... an ultraviolet purifier so her water is clean. "
how often are the bulbs changed? the spectrum burns out and they need to be replaced, check with the manufacture. At some point they are just purple lights and don't kill anymore.
if it were me, I'd put the effort into sealing out critters, dirt, etc.
