Smokin' John Deere
/ Smokin' John Deere #11
Re: Smokin\' John Deere
What do you suppose the dried rice added to the mix? Unless I am missing something, dried rice + water + heat = wet rice, soft and mushy.
/ Smokin' John Deere #12
Rice!? In the carb?!!? Surely not!!??
How could all that goop get past the needle and seat?
I just don't see how that could work at all. /forums/images/graemlins/confused.gif
/ Smokin' John Deere #13
Fishman,
</font><font color="blue" class="small">( How could all that goop get past the needle and seat? )</font>
You don't put the water through the fuel system. You put it in the air intake as you would an upper cylinder lubricant.
This is the first that I have heard of using rice along with the water. I suspect that the rice acts as a mild abrasive cleaner. Its probably hard enough to shatter carbon deposits when it hits them at air intake speed but much softer than metal.
This is pretty much Model T Ford technology. Not sure what it do to the oxygen sensor or catalytic converter in todays cars.
/ Smokin' John Deere #14
That's right, about dumping down the carb vents. By the way, I also heard that crushed walnut shells do as well. (Besides using them for 'sandblasting'.) I, too, suspect that it's acting as a sandblasting/chipping agent. Sure is a rough way to cook a meal, th /forums/images/graemlins/grin.gifough!
/ Smokin' John Deere #15
OK that makes sense now. I guess I was just having a senior moment. Still sounds a little strange though.
/ Smokin' John Deere #16
Hi Tim,
I don't know by your post, what engine is in your tractor.I recently I had a two cylinder B&S that smoked real bad. I found out it was a blown head gasket on one cylinder.It was blown between the oil galley and the cylinder bore. This may be your problem or it may be just a tired engine that needs to be overhauled.
Gugy
Volvo ECR235CL (A53317)
Volvo ECR235CL...
HUSQVARNA RIDING MOWER 46IN DECK (A56859)
HUSQVARNA RIDING...
UNKNOWN  500BBL FRAC TANK (A58214)
UNKNOWN 500BBL...
2007 PETERBILT FLAT TOP SLEEPER  385 (A60736)
2007 PETERBILT...
JLG 1930ES ELECTRIC SCISSOR LIFT (A59823)
JLG 1930ES...
John Deere 5100E (A60462)
John Deere 5100E...
