Smoke "outside"
/ Smoke "outside" #1
GerardC
Elite Member
New York
KIOTI CK20 GEAR.
Smoke \"outside\"
After the last time the smoke lingered around in the garage, I figured why not try this. Works great. Gerard
/ Smoke "outside" #2
Re: Smoke \"outside\"
What is that you're using, Gerald?
/ Smoke "outside" #3
Gerald that's a good idea. Years ago we used to use a similar crushproof tube for service stations that my family owned. There were also small openings on the bottom of the bay doors (gun ports) that you could pass the tube out of while the doors remained closed to the cold. They worked quite nicely even back then. This is the company that we used to purchase them from. exhaust system
/ Smoke "outside" #5
I do this too on days when there isn't enough wind to blow the smoke out the door fast
enough or I'm taking off the back hoe and I have to run the tractor while I'm in the garage for a few minutes.
I used radiator hose and a small copper pipe connector. Works great.
Cliff
/ Smoke "outside" #6
Hey Gerard,
Do you have any varmints? I've used this approach with the exhaust pumped into their holes.
/ Smoke "outside" #7
Great idea. I'm going to rig up something similar. If i don't open all the doors my smoke alarms go nuts.
I wonder if a short pipe connecting the exhaust to the air intake would work. noooooo. /forums/images/graemlins/laugh.gif
/ Smoke "outside" #8
Isn't that called a "turbo charger"? /forums/images/graemlins/tongue.gif /forums/images/graemlins/grin.gif
Mark
/ Smoke "outside"
Roy: It's 3" flex hose with rigid vent pipe on the end. Here's a side photo of it taken the night before the snow fell. Gerard
/ Smoke "outside"
PineRidge: Thanks for the link.
When the KIOTI has a permanent parking spot (addition needed) I will put a dryer vent in the wall. Right now it's parked where the Corvette usually is. Gerard
/ Smoke "outside"
Forgot to mention that the door is usually only opened about a foot or so. For photo sake, it was opened all the way. Gerard
/ Smoke "outside" #12
That's a great idea for getting the tractor all warmed up prior to plowing!! ........J
/ Smoke "outside" #13
Good idea. Did you make a sleeve to fit snug over the exhaust pipe? I would think that there might be a risk of carbon monoxide building up in the garage with the door closed. Just thought I'd point out an obvious safety concern.
Take care.
/ Smoke "outside" #14
Good idea Gerald.
Welcome to TBN bluenoser. I'm curious, what is a bluenoser?
Moon of Ohio
/ Smoke "outside" #15
I just notieced, we also have a Jaeger! Cool name. I have a boating buddy we call Jaeger. He normally has a little Jaegermiester on his boat. /forums/images/graemlins/blush.gif
Welcome to TBN Jaeger!
Moon of Ohio
/ Smoke "outside"
<font color="blue">Did you make a sleeve to fit snug over the exhaust pipe?</font>
No. I just slide the flex pipe on. It goes about 4 to 6 inches over the exhaust pipe. Gerard
/ Smoke "outside" #17
Bluenoser is two things:
1) I'm from Nova Scotia and we're called bluenoser's here (after the famous Bluenose schooner);
2) I own a New Holland...it all has a blue nose. /forums/images/graemlins/grin.gif
Cheers
Dan
/ Smoke "outside" #18
Bluenoser....
Where in Canada's Ocean Playground are you located ??
/ Smoke "outside" #19
Thanks for the welcome. I'm not much of a drinker.......That stuff is way tooo much!!!!!!!!!...........J /forums/images/graemlins/smile.gif
/ Smoke "outside" #20
I'm located in Porters Lake...good to see another bluenoser hanging around here.
Cheers
Dan
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2020 Takeuchi TL8R2 Track Loader with 72in Tooth Bucket (A61307)
2020 Takeuchi...
KUBOTA L3301 TRACTOR (A62130)
KUBOTA L3301...
2013 Ram 5500 Bucket Truck, VIN # 3C7WRNALXDG552597 (A61165)
2013 Ram 5500...
2015 VENGEANCE BUMPER PULL CAMPER (A60736)
2015 VENGEANCE...
2013 CATERPILLAR 299D SKID STEER (A60429)
2013 CATERPILLAR...
