Posthole Digger Smallest available auger size?
   / Smallest available auger size? #11
Many years ago I decided to try accelerating the "rotting out" of some of my larger pine stumps. A friend had given me a granular material that was supposed to do this.
So with my generator - Milwaukee 1/2" Hole Hog - 1 3/4" x 36" ships auger - - I drilled MANY holes in many trees. It didn't seem to help a bit.
I also HAD a 2" dirt auger that I tried using to drill around selected fruit trees and then add fertilizer to these drilled holes. It worked for a few holes. Then this auger ran into something tough and the Hole Hog turned the entire dirt drill into a pretzel.
Now I take a four foot length of 3/4" steel pipe and simply drive it down three feet. Pull it out along with the "core" - - add fertilizer down the open hole. Pack it down with a 1/2" x 4" wood dowel. Quick, easy, efficient.
You're pulling it out with the loader, right? Or maybe a fence post puller? :)
   / Smallest available auger size? #12
No, if I "wobbled" the pipe as I drove it down - most would come out by hand. However - there WERE some that required the loader.
   / Smallest available auger size? #13
Deep root feeding is done in the top few inches of soil. There's no need to go deeper than 6".
406 (A52706)
406 (A52706)
Kubota LX2620 (A53317)
202473 (A54757)
202473 (A54757)
2016 CATERPILLAR 325FL CR EXCAVATOR (A52705)
2016 CATERPILLAR...
2024 Timpte 40ft Hopper (A56435)
2024 Timpte 40ft...
2011 Ford Escape XLT SUV (A54815)
2011 Ford Escape...
